BOBCAT CT230 RANGE SELECTOR STICKS
   / BOBCAT CT230 RANGE SELECTOR STICKS #11
.. but I have noticed if I give it a little travel pedal (while throttled down to idle) and ease the RANGE SELECTOR into gear (L-M-H), I'll get a slight "grind" as the gears engage.
I really don't want to grind the gears, so if anyone has another "fix" please reply.
Thanks again for the replies.
:D
Give the pedal a slight 'bump', stop, then try to shift. You're just trying to line the gears up for an easier shift.
Don
   / BOBCAT CT230 RANGE SELECTOR STICKS #12
I just got my CT230 and I noticed the same thing but was expecting it after reading this thread. It feels like a Jeep 4wd lever and seems to respond to the same thing... Just make sure you are rolling ever so slightly when you shift and shifting is smooth.
   / BOBCAT CT230 RANGE SELECTOR STICKS #13
The Bobcat dealer's shop mgr. contacted me and said he talked to BOBCAT - who told him the procedure was in the owner's manual. He offered to come pick up the tractor (60 mi one way) and have his mechanics look it over for any possible problems... like bent linkage. I'm thinking I'll give it awhile longer to see if things improve, then take up the offer if it doesn't get better.
:D
WOW. My dealer is 5 miles away and I'd like to get a return phone call much less them come pick it up to fix it.
   / BOBCAT CT230 RANGE SELECTOR STICKS #14
On a Kioti there is an adjustment in the linkage that will fix this. On mine the creep and hard shifting got worse as hours racked up. I made the adjustment about 50 hours ago and all is good.
Warhammer
Don
   / BOBCAT CT230 RANGE SELECTOR STICKS #15
on my ct230 it shifts a little hard at times also i have just played with back and forth pedal a bit as im pushing clutch in and out seems like its better with time i think i only have 6o hours on it . must say that i really like my machine .
3" X 4" GAS POWERED WATER PUMP (A52708)
3" X 4" GAS...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
154 (A52708)
154 (A52708)
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB23656, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
