Bobcat CT230 / CK30 Front Axle
   / Bobcat CT230 / CK30 Front Axle #1
Canada_CT230
Platinum Member
Nowhere
1878 Ford 65N
Hi,
I own a CT230 (Kioti - CK30 in white). I am getting ready to do the 50 hr service before it freezes up.
In the manual it says the front axle capacity is 4.5L each. Does this mean the entire axle holds 9L? There are two drain plugs but only one fill plug
Any ideas? I need to go to town to get the oil and want to make sure I get it all before I start.
Thanks!
   / Bobcat CT230 / CK30 Front Axle #2
As I recall, I put a bit less than a gallon and a half of 80/90 gear oil in
my Kioti (which has 2 filler caps, two drains, and one sight glass). It
takes a while for it all to get distributed. Kioti put clear hyd oil in mine
when new, but recommends gear oil.
   / Bobcat CT230 / CK30 Front Axle #3
You may want to ask your Bobcat dealer what they recommend.
   / Bobcat CT230 / CK30 Front Axle #4
Hi,
I own a CT230 (Kioti - CK30 in white). In the manual it says the front axle capacity is 4.5L each.
I see the entry that says "4.75 qt each". Strange. I think you will see how
much comes out if you use a pan. I will bet that it is hyd oil. 80W/90
is specced (p. SPEC9) as with the Kioti.
   / Bobcat CT230 / CK30 Front Axle #5
Hi,
Thanks!
When I changed mine I put in about four liters and it put it half way in the sight glass, then after I used it once I put in about another half liter or so to top it up.
Steve
   / Bobcat CT230 / CK30 Front Axle #6
You could probably find this in past posts, but after you fill it up to half of the sight glass, drive it around a few hundred yards and you'll see it needs more as Steve mentioned. There must be air pockets that will fill after driving. This seems to happen to almost everyone. My CK30hst had hydro fluid when new and I used 80/90 for the refill as stated in my manual.
   / Bobcat CT230 / CK30 Front Axle #7
Very true. I was adding oil to my tractor's axle for months after the change.
It will be more of an issue with the Bobcat as they have eliminated the fill
hole on the right side. So all your gear oil has to make it thru the diff to
the right axle. That means you need to seriously OVERfill the left side.
50 hr service is done now. Engine oil change was easy and clean. Hydrostatic/differential was easy too. Time consuming with the large amounts of oil to deal with. The front diff did take ~ 4.5L of gear oil. It was a pain in the butt as it was low...then add...then drive...then add...then drive...then too full...then drain a bit...then drive...then too low...then add...then finally good. PITA that was. Hard to judge what stays in the cavities that will never drain out.
Done and good for winter now! Thanks for the info.
2024 Quality Steel Deck Over Tilt Trailer (A59814)
2024 Quality Steel...
2018 HINO 338 26FT CDL REQUIRED BOX TRUCK (A59575)
2018 HINO 338 26FT...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2019 CHEVROLET SILVERADO 11FT FLATBED (A59575)
2019 CHEVROLET...
