Bobcat 331 Return to Tank
/ Bobcat 331 Return to Tank #1
TSXJ1197
Yanmar 135D
hey guys, first post here!
I've been wanting to get a flail mower attachment for our 331 but to my understanding it has 3 lines. supply, return, and case drain line but our machine doesn't have an aux case drain. I hear there is a kit but I'm unsure of where to plumb the aux drain to? Can i essentially get another filter assembly and plumb it in before the motor case drain filter or will this cause back pressure issues? I believe the 334 has an aux case drain and that they're essentially the same machine just has more power.
Any advice would be helpful!
Thanks,
Nate
/ Bobcat 331 Return to Tank #2
Tee the case drain line into inlet end of the case drain filter, no extra filter needed. 334 is a 331 with a longer dipper arm no other differences if in same production era.
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2017 Ford E-450 Super Duty Shuttle Bus (A66736)
2017 Ford E-450...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2006 FORD E450 UTILITY TRUCK (A66091)
2006 FORD E450...
2018 MERLO TF30-9-11.5 TELESCOPIC FORKLIFT (A63276)
2018 MERLO...
