boat question
/ boat question
Shimon said:
Well, that's certainly good news. If it runs fine then stick with it. As long as nothing is bent you should be ok. Probably had a little damage to bearings and possibly rings/walls but run it till you need a new one or a rebuild.
Is the sterndrive unit a Volvo? If I remember correctly they had a bulletin out about flapper valve failures and had some sort of fix. I'm not a sterndrive expert but I do remember that much.
The sterndrive unit is a Mercruiser
4021 (A59228)
4021 (A59228)
Woodland Mills Sawmill (A65579)
Woodland Mills...
UNUSED ATSPOWER 40 GALLON AIR COMPRESSOR (A64281)
UNUSED ATSPOWER 40...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
Coleman Back Home Screen House (A62613)
Coleman Back Home...
Massey Ferguson 383 Tractor (A64047)
Massey Ferguson...
