blown off tire.
/ blown off tire. #11
What are your tire pressures? Normally tires getting popped off the rims is a sign of too low pressure. Of course, low pressure also gives you a little better traction. In my Mule, I keep the pressure pretty high because of the loads I carry, normally around 30 psi.
/ blown off tire. #12
Do these machines have a bead lock made into the wheel ? I have several ATV'S & they all have bead lock wheels . The down side to the bead lock wheels are, they are very hard to break the tire off the wheel for tire replacment. I have never seen an ATV tire come off the wheel going through rough areas .
/ blown off tire.
right now because of a massive plugged hole in the front tire (the one that blew off) it took me about 4 plugs i stuck two fingers into the hole . i'm just glad the plugs held so for.thats what i thought blew when i heard the air but it was the tire blowin off the rim instead. but right now i run 10 psi in the front and 20psi in the back. i got some stock 489's. i got some some 27'' itp 589's comin in about two days. payed 560.00 for the tires and rims.
/ blown off tire. #14
</font><font color="blue" class="small">( Do these machines have a bead lock made into the wheel ? I have several ATV'S & they all have bead lock wheels . The down side to the bead lock wheels are, they are very hard to break the tire off the wheel for tire replacment. I have never seen an ATV tire come off the wheel going through rough areas . )</font>
They are easy to break on a ATV. You are using the wrong tool. /forums/images/graemlins/grin.gif
/ blown off tire. #15
/ blown off tire.
i agree they are very easy to break if you have the right tool . they sell them on the internet or you could just make one. if not a heavy duty 1'' wide by 1/4'' thick paint craper and a 4lb mall works great /forums/images/graemlins/grin.gif but i recomend the tool. i'm runni 15lbs of air in the front and back with my new tires and they seem to work great
/ blown off tire.
/ blown off tire. #20
It's a small bead around the inside of the wheel. Example ; run a lawntractor low of air and turn , the tire will break from it's bead (seal) of the wheel . An ATV tire won't do this because of the bead lock.
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
2019 GALLEGOS TRAILER PNEUMATIC TRAILER (A60736)
2019 GALLEGOS...
1995 John Deere 5300 (A60462)
1995 John Deere...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
207273 (A52708)
207273 (A52708)
