blown off tire.
/ blown off tire. #1
TOMMYHPX4X4
schriever, louisiana terrebonne parrish
gator hpx 4x4
here are some pics of my gator today i went into a rut and the tire broke the seal on the rim. i then had to winch it out the hole backwards . lcky i got the quik connects on my winch and i can hook it up in the front or the back.
/ blown off tire.
sorry the pics didn't come out
/ blown off tire. #6
Wow that must suck. I take it you have an HPX right ? I just got mine a few weeks ago and have been wanting to put it through some mud but cant find any /forums/images/graemlins/frown.gif do you think you could have made it through that given you didn't blow the tire ?
/ blown off tire.
yea i make it through that rut everyday. and to think the rut is about 1'1/2 deep. i helped make it but i only have 6'' of clearance. them lugs on the side of the rear tires help out alot.
/ blown off tire. #10
Wow im bringing my gator down there to your mud hole! /forums/images/graemlins/smile.gif
/ blown off tire. #11
What are your tire pressures? Normally tires getting popped off the rims is a sign of too low pressure. Of course, low pressure also gives you a little better traction. In my Mule, I keep the pressure pretty high because of the loads I carry, normally around 30 psi.
/ blown off tire. #12
Do these machines have a bead lock made into the wheel ? I have several ATV'S & they all have bead lock wheels . The down side to the bead lock wheels are, they are very hard to break the tire off the wheel for tire replacment. I have never seen an ATV tire come off the wheel going through rough areas .
/ blown off tire.
right now because of a massive plugged hole in the front tire (the one that blew off) it took me about 4 plugs i stuck two fingers into the hole . i'm just glad the plugs held so for.thats what i thought blew when i heard the air but it was the tire blowin off the rim instead. but right now i run 10 psi in the front and 20psi in the back. i got some stock 489's. i got some some 27'' itp 589's comin in about two days. payed 560.00 for the tires and rims.
/ blown off tire. #14
</font><font color="blue" class="small">( Do these machines have a bead lock made into the wheel ? I have several ATV'S & they all have bead lock wheels . The down side to the bead lock wheels are, they are very hard to break the tire off the wheel for tire replacment. I have never seen an ATV tire come off the wheel going through rough areas . )</font>
They are easy to break on a ATV. You are using the wrong tool. /forums/images/graemlins/grin.gif
/ blown off tire. #15
/ blown off tire.
i agree they are very easy to break if you have the right tool . they sell them on the internet or you could just make one. if not a heavy duty 1'' wide by 1/4'' thick paint craper and a 4lb mall works great /forums/images/graemlins/grin.gif but i recomend the tool. i'm runni 15lbs of air in the front and back with my new tires and they seem to work great
/ blown off tire.
/ blown off tire. #20
It's a small bead around the inside of the wheel. Example ; run a lawntractor low of air and turn , the tire will break from it's bead (seal) of the wheel . An ATV tire won't do this because of the bead lock.
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2015 FREIGHTLINER CASCADIA DAY CAB 6X4 (A59906)
2015 FREIGHTLINER...
2008 CHEVROLET EXPRESS VAN (A60736)
2008 CHEVROLET...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
DITCH WITCH JT60 ALL TERRAIN HORIZONTAL BORING MACHINE (A60736)
DITCH WITCH JT60...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
