blowing PTO fuse while mowing
/ blowing PTO fuse while mowing #1
freddymac63
My Kioti DS4110 keeps blowing the PTO fuse after an hour or so of mowing. If I replace the fuse it immediately blows it again. If the I let the machine cool off for a couple hours she'll mow 30-45 minutes before blowing the same fuse. Hydraulic oil is clean and full. I replaced the PTO switch several hundred hours ago and should probably do it again.
Any thoughts on what's going on?
/ blowing PTO fuse while mowing #2
I would look real close for a chaffed wire or a loose ground.
/ blowing PTO fuse while mowing #3
Can you access the coil connection on the PTO engagement valve? If yes use an ohm meter to check coil resistance cold and then when gets hot and blows the fuse. Possible coil is heating up and shorting out internally.
/ blowing PTO fuse while mowing #4
Deffently sounds like a short. Usually when a coil gets hot it
would normaly open when there bad?? caps are great for that
Any wires where there's heat or loose so they could ground out?
willy
FORKLIFT (A56857)
FORKLIFT (A56857)
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
Chevrolet 2500 Flat bed (A61306)
Chevrolet 2500...
Honda UTV (A56859)
Honda UTV (A56859)
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
