blowing PTO fuse while mowing
   / blowing PTO fuse while mowing #1
freddymac63
My Kioti DS4110 keeps blowing the PTO fuse after an hour or so of mowing. If I replace the fuse it immediately blows it again. If the I let the machine cool off for a couple hours she'll mow 30-45 minutes before blowing the same fuse. Hydraulic oil is clean and full. I replaced the PTO switch several hundred hours ago and should probably do it again.
Any thoughts on what's going on?
   / blowing PTO fuse while mowing #2
I would look real close for a chaffed wire or a loose ground.
   / blowing PTO fuse while mowing #3
Can you access the coil connection on the PTO engagement valve? If yes use an ohm meter to check coil resistance cold and then when gets hot and blows the fuse. Possible coil is heating up and shorting out internally.
   / blowing PTO fuse while mowing #4
Deffently sounds like a short. Usually when a coil gets hot it
would normaly open when there bad?? caps are great for that
Any wires where there's heat or loose so they could ground out?
willy
Mini John Deere Truck (A55853)
Mini John Deere...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2019 Ford Transit Connect Cargo Van (A56858)
2019 Ford Transit...
SKID STEER ATTACHMENT MULCHER (A58216)
SKID STEER...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
