blowing PTO fuse while mowing
/ blowing PTO fuse while mowing #1
freddymac63
My Kioti DS4110 keeps blowing the PTO fuse after an hour or so of mowing. If I replace the fuse it immediately blows it again. If the I let the machine cool off for a couple hours she'll mow 30-45 minutes before blowing the same fuse. Hydraulic oil is clean and full. I replaced the PTO switch several hundred hours ago and should probably do it again.
Any thoughts on what's going on?
/ blowing PTO fuse while mowing #2
I would look real close for a chaffed wire or a loose ground.
/ blowing PTO fuse while mowing #3
Can you access the coil connection on the PTO engagement valve? If yes use an ohm meter to check coil resistance cold and then when gets hot and blows the fuse. Possible coil is heating up and shorting out internally.
/ blowing PTO fuse while mowing #4
Deffently sounds like a short. Usually when a coil gets hot it
would normaly open when there bad?? caps are great for that
Any wires where there's heat or loose so they could ground out?
willy
2012 CTS BELLY DUMP (A67714)
2012 CTS BELLY...
2013 VOLVO A40F OFF ROAD DUMP TRUCK (A65056)
2013 VOLVO A40F...
2012 Ford F-250 Crew Cab Pickup Truck (A66736)
2012 Ford F-250...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2023 JOHN DEERE 35P EXCAVATOR (A65056)
2023 JOHN DEERE...
