Blocking mouse access?
/ Blocking mouse access? #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
After years & years, I have finally figured out how mice are getting into & under the house, thanks in part to a ground squirrel that got under the house. There is a little gap between the furnace and the garage foundation. Somewhere behind the furnace there must be access. But I can't get to it. Access to that area for humans is blocked by a water heater & a well pressure tank.
This week, the pressure tank is getting replaced, so for a brief period I'll have some access. So how can I best block that gap behind the furnace and do it quickly so the tank guy isn't delayed too long?
My first idea is to squirt in insulation foam, the kind that comes in pressure cans. I figure if the mouse doesn't see an entrance, he won't go there. Have also thought about wadding up some metal window screen material and jamming it in there and maybe using the foam along with it, so if for some reason they get thru the foam or it disintegrates over time the screen will block access.
Any better ideas?
Thanks.
/ Blocking mouse access? #2
use steel wool, and something waterproof, maby silicon?
/ Blocking mouse access? #3
Steel wool all the way. About the only thing mice will not chew through.
/ Blocking mouse access? #4
+1 on the steel wool and if you want to make it solid, foam or caulk it in place. A little bleach will also remove any previously left odour trail that helps rodents that are new to the neighbourhood find their way!
/ Blocking mouse access? #6
Another steel wool yes.
Spray insulation mice will nibble at for another home,and before you know it they will be back in your home.
/ Blocking mouse access? #7
Seen mice gnaw through foam over night...
Metal/cement is your best bet... Steel Wool next and it is quick and easy.
/ Blocking mouse access? #8
A hungry cat!
Morter works well also.
Use a small trowel and pack all gaps with the morter.
Also for larger gaps U can use the metalic stucco lath, even wire type screening is good.
Have fun!
/ Blocking mouse access? #9
Put some steel wool in place and then expanding foam all around it to seal the hole. Before it completely dries, on the outside access spray some good strong poison to absorb into the foam. 3X protection.
/ Blocking mouse access? #10
I have used steel wool in the past and it works. Cheap too. :D
We had mice getting into the attic. The only way I can see how they could get in was by climbing the coax cable entering the attic space. VERY small opening and how/why the wee buggers find that opening is beyond me. So I put in steel wool.
A couple nights ago I checked the attic....
I had put down some batt insulation to cover some places either this year or last. I cannot remember. :eek: I put the steel wool into place this year. On top of the batt insulation was mice poo! :mad::mad::mad::mad:
It is possible the mice got into the attic after I put down the insulation and before I put up steel wool which I installed during the hot summer to make sure the mice were out of the attic. But that mouse poop looks fresh.
The only way I can see them getting into the attic is if the mice can climb vertical brick walls. :eek:
Putting in steel wool is easy.
Finding WHERE to put the steel wool is not so easy. :eek::D
Later,
Dan
/ Blocking mouse access? #11
Steel wool seems to work well at my house. Use a lot of it and tuck it in tightly. A couple of times I have noticed that a mouse (or something) had pulled out some of the wool from the cracks. That's why I now add a little extra and shove it in tightly with a small stick. Perhaps the mice were trying to get out instead of in.
/ Blocking mouse access? #12
Mice!:mad: I've caught 6 mice in my house this winter so far. I've never had mice before for well over a decade and even then it was just a couple since I bought the place in 1981. I have no idea where they all came from. :confused:
The first time I saw the first one of the bunch, I thought my eyes were playing tricks on me in my old age and I was seeing things. That happened a couple of times and then finally I got a good look at the little fellow. I set out an old fashioned "snap trap" and soon ended his life. Made me kinda sad in a way, poor little mouse didn't mean anyone any harm and was just trying to find a cozy winter home. After that I caught another, then another! Even managed to catch one alive in a plastic grocery bag he was raiding. Altogether I ended up with six of them and I hope that's the last I ever see of them in the house.
/ Blocking mouse access? #13
Steel wool, spray foam and then perhaps some fine (1/4" mesh) hardware cloth stapled to the wall as backup.
Aaron Z
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
Deere 333E (A60462)
Deere 333E (A60462)
3pt 20' Cultivator (A64119)
3pt 20' Cultivator...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
2021 Chevrolet Equinox SUV (A61574)
2021 Chevrolet...
2021 John Deere S790 Combine (A63111)
2021 John Deere...
