TX25H tractor and loader
TX25H Tractor & Loader $19,999
Atwoods • Family Farm & Home
Farm & Home Supply • The Home Depot
Runnings • Tractor Supply
Find Your Nearby Retailer
TX25H tractor and loader with backhoe
TX25H Tractor & Loader w/Backhoe $27,999
Ad top of page
Block heaters
/ Block heaters #1
white4768
summit tx25
Any time the temp is below 50 deg tractor will not start I have to put a heater on it. glow plugs get turned on three four times does not help. thinking of adding a block heater.
/ Block heaters #2
Something sounds off. Just started my D702 Kubota @ 10 F, cycled the Glow Plugs twice, fired, twice again and started. (at about 1/2 throttle)
Still has Summer Fuel (with Conditioner)
Are you sure your Glow Plugs are working?
/ Block heaters #3
Happy New Year, Summit gang.
Chiming in to say I’m in a cold winter climate and get my TX25 started in (well) below freezing weather using the following:
Hot Shots Winter Anti-Gel diesel treatment
Battery on a charger/trickle all winter
KAT’s 200 watt Magnetic Block Heater
I use the block heater on the oil pan for an hour or two, but I believe it has an auto-off feature.
Although I think about it…I have not used a temperature gun to determine whether or not the ‘heater’s actually making a difference. That said, the product gets great reviews.
/ Block heaters #4
You need to verify glow plug circuit is operational. I had to replace my glow plugs when it became harder and harder to start in 50° weather. Now with new plugs, she starts first time in 5°F weather.
/ Block heaters #5
Agree with all here and my $0.02 is that a lower radiator hose heater might be an easier option for you also. Mine works great for years!
/ Block heaters #6
Recently had the same issue with my Summit and discovered loose wire connections on the Bosch glow plug control module.
The module is located at the front of tractor under the hood on the right side as your sitting on tractor.
You will need to remove module to tighten connections as they are on the bottom.
/ Block heaters #8
I feel your pain white4768. I had same problem.
Installed a lower radiator hose heater. Plug in and let it heat for an hr. and a half or so would fire right up. Talked around to a couple of my diesel friends and they said the glow plugs are not working. Started watching videos and testing and reading above posts (thanks guys) glow control unit was not getting 12v power. The plug in the wire connecting battery to control unit was plugging together inside the plug housing. Fixed the plug. Went out Friday morning before work at 10 deg outside, cycled glow plug twice and fired right up without using hose heater. Made me very happy to fix this issue but a little disappointed that this feature was never checked when tractor was assembled.
Lower hose heater is a great idea though for real cold
times so your fluids do get a little warmed up. Do not have to let tractor run nearly as long before getting to
work.
/ Block heaters #9
CORRECTION
I should always read my post before sending.
The plug inside the housing was not plugging together.
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
215603 (A63276)
215603 (A63276)
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
2017 Ford Fusion (A64557)
2017 Ford Fusion...
JOHN DEERE S690 COMBINE (A64278)
JOHN DEERE S690...
Spirit Bike (A64557)
Ad bottom of page
