Block heaters
/ Block heaters #21
They do work great, the worst problem is finding the room to put one. I have one on my 166 hp Perkins generator and it is warm anywhere you touch it. When it starts, it's just like it was just turned off. I bought one for my new tractor and have yet to find a place to put it. Actually I haven't looked very hard. /forums/images/graemlins/smile.gif
It looks like all tractors would have a place to connect the hoses if you can put a cab with heat on.
/ Block heaters #22
I am far from an expert but I have a problem with blockheaters on timers. They create condensation cycles. As the warm engine block is cooling down after the power is removed, it makes an exellent moisture collector, both on the inside and outside of the engine. You will be surprised by the amount of water you can find in the oilpan after a couple of blockheater cycles without starting the engine and boiling off the water. I've seen major damage done to aircraft engines this way, both due to corrosion of steel parts and the lack of lubrication due to massive amounts of water in the oil. if you do want to use a timer, I would suggest to use one of those fancy 7 day timers, that way you only get one cycle if you can't make it one week in stead of 7 cycles
pete
/ Block heaters #24
If the block heater you have is like the ones I've had in a couple of Benzes, these are heating elements, which typically draw quite a bit of amperage and aren't on a temperature sensor. They'd boil the water if it weren't for heat loss probably being higher than they can input.
You really only need to put them on about an hour before starting the vehicle. That's it. Otherwise, you're wasting electricity.
Ralph
/ Block heaters #25
The block heaters are temperature controlled. They do not run continually unless required. They will cycle on and off as required.
Typically they draw from 750 to 1500 watts.
Egon
/ Block heaters #26
755inNY,
I was usually smart enough to sit and wait while it warmed up. Until it finished it's fast idle cycle, trying to rush it would almost always end up with more time spent with freeing up the choke. On the way home, I was usually more patient.....
Thks,
Ron
2022 EZ-GO ELITE...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
LOAD OUT AND SHIPPING (A65563)
LOAD OUT AND...
2015 Ford Escape 4WD SUV (A61574)
2015 Ford Escape...
Caterpillar 928F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 928F...
Caterpillar 400B Series Backhoe Service, Parts, and Operation Manuals (A63117)
Caterpillar 400B...
