Block Heater
/ Block Heater #1
Kubota 2350
Platinum Member
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
I have a JD installed block heater on my 3046, anyone know how long it takes to heat the engine up once it's plunged in?
/ Block Heater #2
No, but pls keep us informed.
And ?, heated up to what? 'til it starts? or 'til the heater shuts off?
/ Block Heater #3
It's all physics.
Abient temperature
Block temperature
Size of block
Inside or outside (wind)
Heater watts
Supply Voltage
Give us these details and we can get to arguing how long it's gonna take.
No heater I have ever seen shuts off. That would be good.
Now. Just sayin. Usually 45 minutes for any of my heaters is a good place to start.
/ Block Heater #4
Your block heater will have a noticeable effect after three or four hours. A lot will depend upon where the tractor is stored and the ambient temperature.
/ Block Heater #5
I've never seen a block heater that shuts off? Every one I've seen is just a heating element with a cord. 15 amps @120v isn't enough to make enough heat to need a controller IME.
~2 hours. Be careful with timing though, if the GP controller is automatic off of coolant temp then you need to either let it set 2+hours or not at all and just crank. For example my TDI will not cycle the glow plugs at all if I have only had it plugged in for 30 mins so it won't even try to fire up. If I'd left it unplugged it would have probably started with a jump.
/ Block Heater
I store in inside my unheated barn, left it plugged about 2 hours today and it seems like I got heat in the cab quicker than normal, that is all I was looking for.
As far as helping it start, I've never had any problems with it starting even if below zero.
Wattage of heater is unknown, what ever the dealer installed before they delivered it to me, I do know the heater is a JD part..
Thanks for the help. :thumbsup:
/ Block Heater #8
My truck wouldn't cycle the glow plugs if the engine was warm. It doesn't like the idea of a no glow plug start either. I fixed the problem by putting a manual button on the plugs.
/ Block Heater #9
On my allis Chalmers 185 and my 730 John Deere I usually give about 2 hours. If it is way zero and colder I give it 3-4 hours. I have pretty good luck with block heaters. Both tractors are parked in an open pole barn/machine shed. Bath tractors have medium to larhe motors that are exposed on both sides. My mf won't start in cold weather, it is a joke. Pretty sad when tractors 40+ years old will start, while a modern mf is worthleas in the cold cause it won't start.
/ Block Heater #10
I put mine on a timer to come on at 4 AM that way it has a good 2 hrs. minimum to warm things up but when I start at 3 hrs. I notice the it gets up to temp. much faster for the heater in the backhoe & the tractor starts just like it's been running without using the glow plugs.
/ Block Heater #11
john deere also offers a trans heater, the problem with block heaters is operator forgets that 9 gallons of cold oil in the trans , if you let the engine warm normally it also warms the trans ,I use to plow snow with wheel loaders , and we had block heaters so the loaders would start , it would take a long time for that 30 gallons of oil and all that steel to warm up ,
/ Block Heater #12
Generally 1-2 hours of heat will do the trick.
A timer can be used or like I did I have an outside outlet that is switched from inside my house.
Some folks leave the heater on 24/24 as well but most heaters draw 200-400 watts and that cost U.
Hardware stores and many auto parts will have suitable timers which run in the $20-25 range.
Presently I have a remote that is operated via a key fob device like for garage doors and remote car starters.
/ Block Heater #13
I have a block heater in my Branson 8050, it uses a manifold heater for cold starting. I found out that it will not run the manifold heat
if I have the block well warmed up (2 - 4 hours) I can cycle the key several times and get some heat into the intake or unplug the temp
sensor for the heater, what I am going to do one day this winter is measure the resistance when its cold and wire in a resistor so the
heater will run better. I would like to add an hydraulic oil heater to it one of these days.
RoGator RG1300C (A63688)
RoGator RG1300C...
2007 Cadillac DTS Sedan (A61574)
2007 Cadillac DTS...
Caterpillar 259D3 Compact Track Loader Skid Steer (A61572)
Caterpillar 259D3...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2020 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
