block heater usage
/ block heater usage #11
I'll look at see if its there, I believe it might be an extra option.
/ block heater usage #13
Typically a dealer installed item. Some dealers in the cold areas automatically install them in all machines. Mine didn't come with one so I picked one up from the dealer last week and is the frost plug style. You likely don't have one but its worth looking in case.
/ block heater usage #14
Mind me asking what the block heater ran you with the 10deg days here lately I am thinking about it thanks
/ block heater usage #15
i got a sweet deal on mine--when it bought the tractor it had a scratch that the dealer was going to buff out. I said how about a free block heater and he bit. I think he said it was a $90 item. this was freeze plug style for a 335.
as a side not when installing I left the heater part in and used a impact socket to bang on and get it lined up perfectly. This will make sense when you see them. I had mine plugged in for 2 hours today when it was 5 above and block was most of the engine was warm. Fired up no problem
/ block heater usage #16
I have had freeze plug style heaters on all my diesel compact tractors going back to 1991. They have been a dealer installed item and they work superbly. Since I didn't want to leave mine plugged in all night I put the heater plug-ins on timers and set them so they would heat up for about 2 hours before the intended use of the tractor.
Tractors always started, providing I could.
/ block heater usage #17
I have the auxiliary heater in my CT225. What is the appropriate use for this when cold starting? Plug it in an hour ahead of time? I would guess you wouldn't want it to be plugged in all the time when not using.
It really depends on the temperatures you are experiencing. I can get by with an hour as long as the temps ar between 32F and 10F. At -15F I need 1-1/2 hrs. Leaving it on longer than 2hrs will not buy much. I have mine on a timer that turns on at 2:30 pm and I feed at 4:00 pm. The tractor starts in a half a turn. If I know it's going to be colder than -15F, I'll turn it on a half hour earlier. I wish I had aheater in the hydraulics because they are really slow to warm up at low temps.
/ block heater usage #18
I bought mine on ebay for $18 plus shpg a couple of years ago. It was a genuine Ford part and was made by Phillips-Temro. (www.phillipstemro.com)They are not expensive and they take about 20 minutes to install IF you have easy access to the core plug.
/ block heater usage #19
I got it from a bobcat dealer and charged me $82.99. Search PN 70000-00297 and you will find the same kit. I believe that PN is a Kubota number. The block heater that i got is made by zero start.
/ block heater usage #20
Yeah well mine doesnt have one and it wont start below 10*F looks like I need to keep it in the heated garage for now on.
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
INSPECTION (A61166)
INSPECTION (A61166)
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
iDrive TDS-2010H...
