block heater usage
/ block heater usage #1
gaberelli
I have the auxiliary heater in my CT225. What is the appropriate use for this when cold starting? Plug it in an hour ahead of time? I would guess you wouldn't want it to be plugged in all the time when not using.
/ block heater usage #2
If you're not worried about paying for the power you could leave it plugged in all the time. It won't do any harm. At a minimum I would plug it in 3 or 4 hours prior to use to let the heat move throughout the entire block.
/ block heater usage #3
I use mine 1hr before I'm ready to start on coldest days.
Thanks for the feedback. I will probably just plug it in when I get home from work and plow after dinner. Fortunately, the tractor will be right next to me in the garage. I also hooked up a battery conditioner to keep the juice flowing. Gotta love the Northwoods!!!
/ block heater usage #5
On my last diesel, I bought a programmable timer from the hardware store. Depending on my schedule & snow forecast, I would just have it come on 1-2 hours before plowing. Worked great.
Just remember to unplug the cord before you pull out......don't ask how I know :rolleyes:
JayCat
/ block heater usage #6
Make sure that you get a timer that can handle the heater's wattage. Don't ask how I know.
/ block heater usage #7
The time required for heating outside may vary according to wattage of heater, mass of tractor that is heated, ambient temperature and the prevailing wind.
Plug it in and do a hand check for warmth on the block. This may be one way to determine the amount of time required for your situation.:D
/ block heater usage #8
Is the block heater standard equipment? If so where is it located? Has anyone had cold starting problems? Mine has been a bugger to start as of late. Been about 10F lately.
/ block heater usage #9
On Kubota its standard.
Check for male cord end..maybe well hidden.
/ block heater usage #10
on my ct230 its on left side neer the starter
/ block heater usage #11
I'll look at see if its there, I believe it might be an extra option.
/ block heater usage #13
Typically a dealer installed item. Some dealers in the cold areas automatically install them in all machines. Mine didn't come with one so I picked one up from the dealer last week and is the frost plug style. You likely don't have one but its worth looking in case.
/ block heater usage #14
Mind me asking what the block heater ran you with the 10deg days here lately I am thinking about it thanks
/ block heater usage #15
i got a sweet deal on mine--when it bought the tractor it had a scratch that the dealer was going to buff out. I said how about a free block heater and he bit. I think he said it was a $90 item. this was freeze plug style for a 335.
as a side not when installing I left the heater part in and used a impact socket to bang on and get it lined up perfectly. This will make sense when you see them. I had mine plugged in for 2 hours today when it was 5 above and block was most of the engine was warm. Fired up no problem
/ block heater usage #16
I have had freeze plug style heaters on all my diesel compact tractors going back to 1991. They have been a dealer installed item and they work superbly. Since I didn't want to leave mine plugged in all night I put the heater plug-ins on timers and set them so they would heat up for about 2 hours before the intended use of the tractor.
Tractors always started, providing I could.
/ block heater usage #17
It really depends on the temperatures you are experiencing. I can get by with an hour as long as the temps ar between 32F and 10F. At -15F I need 1-1/2 hrs. Leaving it on longer than 2hrs will not buy much. I have mine on a timer that turns on at 2:30 pm and I feed at 4:00 pm. The tractor starts in a half a turn. If I know it's going to be colder than -15F, I'll turn it on a half hour earlier. I wish I had aheater in the hydraulics because they are really slow to warm up at low temps.
/ block heater usage #18
I bought mine on ebay for $18 plus shpg a couple of years ago. It was a genuine Ford part and was made by Phillips-Temro. (www.phillipstemro.com)They are not expensive and they take about 20 minutes to install IF you have easy access to the core plug.
/ block heater usage #19
I got it from a bobcat dealer and charged me $82.99. Search PN 70000-00297 and you will find the same kit. I believe that PN is a Kubota number. The block heater that i got is made by zero start.
/ block heater usage #20
Yeah well mine doesnt have one and it wont start below 10*F looks like I need to keep it in the heated garage for now on.
832645 (A61166)
832645 (A61166)
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
832616 (A61166)
832616 (A61166)
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
24in Digging Tooth Bucket Excavator Attachment (A60352)
24in Digging Tooth...
