block heater usage
/ block heater usage #1
gaberelli
I have the auxiliary heater in my CT225. What is the appropriate use for this when cold starting? Plug it in an hour ahead of time? I would guess you wouldn't want it to be plugged in all the time when not using.
/ block heater usage #2
If you're not worried about paying for the power you could leave it plugged in all the time. It won't do any harm. At a minimum I would plug it in 3 or 4 hours prior to use to let the heat move throughout the entire block.
/ block heater usage #3
I use mine 1hr before I'm ready to start on coldest days.
Thanks for the feedback. I will probably just plug it in when I get home from work and plow after dinner. Fortunately, the tractor will be right next to me in the garage. I also hooked up a battery conditioner to keep the juice flowing. Gotta love the Northwoods!!!
/ block heater usage #5
On my last diesel, I bought a programmable timer from the hardware store. Depending on my schedule & snow forecast, I would just have it come on 1-2 hours before plowing. Worked great.
Just remember to unplug the cord before you pull out......don't ask how I know :rolleyes:
JayCat
/ block heater usage #6
Make sure that you get a timer that can handle the heater's wattage. Don't ask how I know.
/ block heater usage #7
The time required for heating outside may vary according to wattage of heater, mass of tractor that is heated, ambient temperature and the prevailing wind.
Plug it in and do a hand check for warmth on the block. This may be one way to determine the amount of time required for your situation.:D
/ block heater usage #8
Is the block heater standard equipment? If so where is it located? Has anyone had cold starting problems? Mine has been a bugger to start as of late. Been about 10F lately.
/ block heater usage #9
On Kubota its standard.
Check for male cord end..maybe well hidden.
/ block heater usage #10
on my ct230 its on left side neer the starter
/ block heater usage #11
I'll look at see if its there, I believe it might be an extra option.
/ block heater usage #13
Typically a dealer installed item. Some dealers in the cold areas automatically install them in all machines. Mine didn't come with one so I picked one up from the dealer last week and is the frost plug style. You likely don't have one but its worth looking in case.
/ block heater usage #14
Mind me asking what the block heater ran you with the 10deg days here lately I am thinking about it thanks
/ block heater usage #15
i got a sweet deal on mine--when it bought the tractor it had a scratch that the dealer was going to buff out. I said how about a free block heater and he bit. I think he said it was a $90 item. this was freeze plug style for a 335.
as a side not when installing I left the heater part in and used a impact socket to bang on and get it lined up perfectly. This will make sense when you see them. I had mine plugged in for 2 hours today when it was 5 above and block was most of the engine was warm. Fired up no problem
/ block heater usage #16
I have had freeze plug style heaters on all my diesel compact tractors going back to 1991. They have been a dealer installed item and they work superbly. Since I didn't want to leave mine plugged in all night I put the heater plug-ins on timers and set them so they would heat up for about 2 hours before the intended use of the tractor.
Tractors always started, providing I could.
/ block heater usage #17
It really depends on the temperatures you are experiencing. I can get by with an hour as long as the temps ar between 32F and 10F. At -15F I need 1-1/2 hrs. Leaving it on longer than 2hrs will not buy much. I have mine on a timer that turns on at 2:30 pm and I feed at 4:00 pm. The tractor starts in a half a turn. If I know it's going to be colder than -15F, I'll turn it on a half hour earlier. I wish I had aheater in the hydraulics because they are really slow to warm up at low temps.
/ block heater usage #18
I bought mine on ebay for $18 plus shpg a couple of years ago. It was a genuine Ford part and was made by Phillips-Temro. (www.phillipstemro.com)They are not expensive and they take about 20 minutes to install IF you have easy access to the core plug.
/ block heater usage #19
I got it from a bobcat dealer and charged me $82.99. Search PN 70000-00297 and you will find the same kit. I believe that PN is a Kubota number. The block heater that i got is made by zero start.
/ block heater usage #20
Yeah well mine doesnt have one and it wont start below 10*F looks like I need to keep it in the heated garage for now on.
Sdlanch 20'x20' High End Carport (A60463)
Sdlanch 20'x20'...
2015 Ford F-250 Pickup Truck (A61568)
2015 Ford F-250...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59908)
2016 INTERNATIONAL...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A61307)
Adams Load Out...
2020 DRAGON ESP...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
