Blitz Non-spill Fuel Can
/ Blitz Non-spill Fuel Can #41
</font><font color="blue" class="small">(
Intersting point here in PA. I have shopped various stores in my search for other fueling alternatives. The blue Kero containers are now on sale for $6.99. The Yellow diesel containers are on sale for $6.99. But, the red gas containers are on sale at $12.99 now /forums/images/graemlins/confused.gif )</font>
Have friend locate spouts in other state, obtain two. Thinking I'm in good shape, attempt to attach spouts to cans. Oh-Oh, different style threads, bad seal at gasket, won't work .
Can the friend get the cans to go with the spouts he got?
/ Blitz Non-spill Fuel Can #42
That's my next plan of attack. Have been using the spring ones until I get other container. Actually, for the amount of gas I'm going through I think I will get one of those "gas Buddy" wheeled containers. /forums/images/graemlins/grin.gif
/ Blitz Non-spill Fuel Can #43
Thinkin' on my next trip over the hill to Reno, I'll have to stop in one of the auto parts stores and see what kind of can I can find there /forums/images/graemlins/smirk.gif ( if I have any money left! )
/ Blitz Non-spill Fuel Can #44
Even in Nebraska it is getting hard to find a "real" gas can in a store. Seems that all states will be getting the junk ones, even if there is no mandate. I found several @ Home Depot and bought 4. Did you try a thicker gasket on the spouts your buddy bought? Maybe we have to buy the new cans, but I'll bet a BUNCH of them will be modified in short order!
/ Blitz Non-spill Fuel Can #45
My blitz jug was full of water and rust contaiminated diesel so I grabbed an old 5 gal jug with flex spout to get some fuel for the tractor.
Good god I made a mess of the thing trying to get the spout to the tank and ended up dumping fuel all over the hood and me.
I'll take the slow blitz can back please!
/ Blitz Non-spill Fuel Can #46
Back in the 70s I had a 5 gallon "jerry can" that I carried on the back of my Landcruiser. I had a long metal threaded spout for it that would make fueling up a little easier. The can sure was heavy when full though.
I found a similar jerry can at generatorjoe.net but the spouts look kind of short. Anyone out there use jerry cans anymore (I would think that the term "jerry", although not truely pc, would be OK to use)?
Bonehead
/ Blitz Non-spill Fuel Can #47
<font color="blue">(I would think that the term "jerry", although not truely pc, would be OK to use)?
</font>
"Jerry" is British slang. I could not find any evidence it's derogatory.
/ Blitz Non-spill Fuel Can #48
(I would think that the term "jerry", although not truely <font color="red"> politically correct. </font> , would be OK to use)?
There is no such thing as <font color="red"> politically correct </font> .
Once it becomes political i'ts no longer correct.
/ Blitz Non-spill Fuel Can #49
</font><font color="blue" class="small">( I found a similar jerry can at generatorjoe.net but the spouts look kind of short. Anyone out there use jerry cans anymore (I would think that the term "jerry", although not truely pc, would be OK to use)?
Bonehead )</font>
Jeeps and other offroaders still use them. They will hold up a lot longer and better than plastic can that will wear a hole in it from rubbing against something.
Bill Tolle
/ Blitz Non-spill Fuel Can #50
"Jerry" is short for a german person used by the brits mainly.
/ Blitz Non-spill Fuel Can #52
I have one. Used it for years. It can be a little slow when temperatures get below freezing. Batteries do not like the cold.
/ Blitz Non-spill Fuel Can #53
I use a yellow Blitz can with a fuel transfer pump that I got at Walmart for less than $20.00 called Flo'n-go LE. (large engine) Works pretty well. It's basically a siphon pump in the shape of a fuel pump handle with a four foot hose. You screw the unit into the Blitz can give the handle a few squeezes to get the fuel flowing. The can needs to be above the tank being filled to keep flowing but that's not a problem I just fold my seat forward and set the Blitz can on the back of it. It's rated flow is 2 GPM so it only takes about three minutes to empty the can. The nice part is that if you let go of the handle the fuel flow stops. While dealing with the hose and all is a little cumbersome, I haven't spilt a drop of fuel on my new tractor. /forums/images/graemlins/grin.gif
-Phil
/ Blitz Non-spill Fuel Can #54
So this thread is two years old, but I didn't have this problem back then. I've had a 2 gallon self venting gas can like this one for several years. It worked great for filling my Toro ZTR because the Toro had a big gas tank and a huge gas cap (filler opening), but when I started using it on the little walk behind mower, it was hard to prevent it from gurgling and splashing. That was solved by drilling a small vent hole in the top rear of the handle with a screw plugging the hole, but removed to pour. But now I had a need for another one, and after going to Home Depot, Lowe's, Walmart, Northern Tool, Auto Zone, Sears, and two independent lawnmower dealers, I found it to be as you see on Northern Tool's website; they are not for sale in Texas, or 11 other states and Washington, DC.
All you can get now are the spill proof ones like this one. The ones I looked at required so much pressure on the spring to open the valve that I'd be afraid of tearing the gas tank off a lawnmower. The lawnmower dealers tell me it's courtesy of the EPA.:rolleyes:
You may have also noticed that the self venting can was $5.99 at Northern Tool, while the spill proof was $14.99.:eek: I found similar prices around here in the last couple of weeks that I've been looking for the kind of gas can I wanted. Well, today I made a short trip up into Oklahoma and while there, stopped in at a Tractor Supply Co. store. The 2 gallon self venting cans were $5.38 each.:p
/ Blitz Non-spill Fuel Can #55
There's a heck of a lot of misinformation in this thread. Here's the straight poop.
Blitz has manufactured three designs of portable tanks.
The pull-n-pour is the old style with the flexible neck and venting cap. This design is no longer manufactured and the cap won't fit the other two designs.
Blitz's self-venting spout vents through the spout and is prohibited for gas or diesel or kerosene in Ca, OH, Nh and Ct. And ONLY in those states. It is prohibited for gas in Tx, Pa, Md, Ny, De, Nj, Me, DC and some VA counties. It is allowed for diesel or kerosene in those later states. It is legal for gas and diesel and kerosene in all other not-mentioned states.
Blitz's spill-proof is the spring loaded cap spout that everyone is grumbling about. It is legal in all states.
I noticed that some of you guys are from Pa, Tx, Nj etc. Well the self venting for diesel is legal in your states. But the self venting for gas is not.
A few months ago I went shopping for self venting diesel blitz cans on ebay and noticed that two big sellers wouldn't ship to my state (Pennsylvania) as they said it was illegal.
I sent them an email asking why they are cutting themselves off from so many states when it was legal to sell diesel self-venting (but not gas self-venting) cans. They contacted Blitz and now they will sell to my state residents.
Now you probably think that I'm blowing smoke but you can check for yourself at the Blitz web site. To help you and verify my statements, here's the web address-
Blitz USA
/ Blitz Non-spill Fuel Can #56
I'm on a roll tonight... so might as well comment...
Another perfect example of regulation run a muck. The mower shop in my neighborhood has had nothing but complaints with the "New" gas cans and has decided to no longer sell any portable gas cans...
/ Blitz Non-spill Fuel Can #57
One of the biggest lawn equipment dealers around here has done the same thing. They'll sell you the equipment, but you have to get your gas cans elsewhere so they don't have to listen to the complaints.
/ Blitz Non-spill Fuel Can #58
Just a thought from my warped little mind. Why not get a group together and every one take their lawn mowers and garden tractors to a busy Gas station line up and buy 50 cents worth at a time. Maybe then the Idiots .. sorry the well meaning people that made up these regulation would come to their right minds .
You would probably need to have the news media around to film it too
Just a thought
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
Atspower Mini Excavator (A60352)
Atspower Mini...
