Blades on a box blade
Status
Not open for further replies.
   / Blades on a box blade #11
Are you worried that your road 9or what ever) is not going to be flat after you do work to it? When you say blades are you talking a land plane (which normally have two blades) or a box blade with a single blade? The only thing I would be concerned with would be the bottom of the blade, the part that actually touches the ground, the part with the holes for the bolts wouldn't bother me one bit if it wasn't flat. Even then I wouldn't worry about the edge not being too flat. Even an inch (which I would think would be pretty extreme) probably wouldn't be noticeable in the dirt over 5 or 6 foot wide blade. I guess that's the real question for you, just how much is it curved?
My box blade does have two blades, one on both sides of the inverted V, because the V is not flat along the length it bends the blade and that results in the edge that touches the ground not to be flat, I have not measured it yet but I'm guessing 1/8" to 1/4" in 60". I figured I would get varying opinions on what exceptable is. I'm not trying to be ****, I just think it should be flat so each pass does not have a dish to it.
   / Blades on a box blade #13
1/8 - 1/4" would drive me nuts- especially if I was doing finish/final grading.
   / Blades on a box blade #14
...I bought a new box blade and when I bolted the blades to the box they have a curve to them along the length....
This would not be acceptable, I would return it and see if another one was better made. What brand is this???
   / Blades on a box blade #15
1/8" flex over a 5 foot blade? Come on guys, this is not a big concern. The blade will wear more that that with minimal use.
   / Blades on a box blade #16
Sorry, not understanding why your asking about my bucket when we are talking about box blades:confused:
Sorry, I edited my post to clarify. Please reread post #8
I really don't want to mention the brand, unfortunately when you mention a brand you get accused of brand bashing and unfortunately the point and subject matter of a thread gets way off subject, at this point I am more interested in other's opinions and what the standard is and what we should expect from a quality built box blade. Not ignoring your question but I think you know my point.
I'm just curious, at what point would you reject a box blade being not flat on the cutting edge, over 60" 1/8"-1/4"-1/2" ? I'm just trying to get some idea of unexceptable. If you had a blade that was not flat do you think it would wear flat Or continue to wear curved.
   / Blades on a box blade #19
Catman, how about a pic of the box blade and the cutting edge?
Jim
Jim
If you read post #17 I really don't want to take a picture because it might give away the brand, and I don't want to be accused of brand bashing or get a lot of people mad, maybe I can try to take a picture without giving away the brand. I have no experiance with box blades and want others opinions who are experienced.
Status
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
New/Unused Quick Attach Pallet Forks - 42 in forks (A57453)
New/Unused Quick...
2017 Ford Transit 350 (A57148)
2017 Ford Transit...
Westfield Conveyor (A56436)
Westfield Conveyor...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
