Blades Collide on 62D Mower Deck
   / Blades Collide on 62D Mower Deck #1
kb2520
John Deere 2520, 200CX Loader, 62D Mid Mount Mower, 5' Box Blade
I have a 2011 JD 2520 with a 62D Mid Mount Mower. In preparing for mowing season, I pulled the blades off the mower, sharpened them, and reinstalled. This I've done at least twice per season since 2011 without issue. Today though, I complete the process of installing the deck on the tractor. With the deck raised and medium RPM, I engaged the PTO as a test. There was a terrible thunk, so I quickly switched off the PTO and shut down the machine. Upon inspection, two of the blades slapped each other as they passed. There was evidence of this in the metal. As I rotated the blades by hand, sure enough they hit each other.
Have I just gotten lucky with the alignment all these years? From the output end, does the first blade need to be positioned North and South, second blade [middle] East and West and the third blade North and South? I honestly do not know if this makes a difference or if I've done something else incorrectly. Sorry for the dunce question, but I could use some input. Thank you!
   / Blades Collide on 62D Mower Deck #2
My guess would be that one blade wasn't centered on the spindle which would offset one maybe an 1/8" or so.
I never heard of tractors having timed blades. Little garden tractor types but they have special belts also.
   / Blades Collide on 62D Mower Deck #3
I assume there are three. Are they all the same length? I can't for the life of me believe there is a mower where the blades are synced. IF they were, the pulleys would have to have teeth to accommodate a timing belt.
   / Blades Collide on 62D Mower Deck #4
Agree with wrong mounting of blades. Once mounted correctly, they won't hit each other..
   / Blades Collide on 62D Mower Deck #5
I wonder if you have two blades mounted wrong (not over the spindle shoulder). On my 62D I don't think one mounted wrong would cause a hit. Upside down won't make a difference in clearance. Take them off and start over and you should be fine.
   / Blades Collide on 62D Mower Deck #6
Maybe you didn't get the blades fully seated on the spindle before putting the nut on. It should be a close fit with no slop, and with no question about north/south and east/west orientation.
   / Blades Collide on 62D Mower Deck #7
Yep, I'm with most others here. You didn't get them properly seated on the shafts. This should be evident by the fact that the blades aren't tightened up against the spool, bit of a gap on top of the blades??
Funny story bout something like this. Many years ago I was running the road grader going by the house of an elderly couple whom I knew very well. The man was on his JD mowing. The wife was standing in the driveway watching. His deck was doing a HORRIBLE job of mowing. When Lois saw me she started waving for me to stop. I got out and as I approached her she said "can you look at our mower and see what's wrong. Bill just sharpened the blades and it isn't working well at all." I said sure. Bill saw me and stopped. A bit embarrassed he said "I don't know what's the matter with this thing." I said let me take a look. I laid down on the ground and looked under the deck thru the discharge chute. Sure enough. The blades were on upside down. As politely as I could I explained my findings to Bill. He really got red faced then. I said pull in the garage and I'll help you swap them. I did it with the deck still on the tractor. He had removed the deck and turned it upside down when he removed/reinstalled them. Laying upside down he had installed them like they would go had the deck been right side up. By the time I got done we were all laughing about it and having a good visit. Couple weeks later I went in my shop to find a case of my favorite Beer sitting inside the door. :D
   / Blades Collide on 62D Mower Deck #8
By chance, were these “replacement” longer blades that you just happened to be lucky that they were synced to not hit each other up until now?
   / Blades Collide on 62D Mower Deck #9
As someone else mentioned, only way to stay "in synch" would be notched belt and pulleys. By design the blades are "creeping" all the time.
   / Blades Collide on 62D Mower Deck #10
I have a mower currently and had another that had different length blades on the center deck. Albeit larger commercial multi wing mowers. Almost any blade I have seen sits very tight on the bolt, to the point of being difficult and annoying to remove. So, I can't see the off-center thing.
An upside down blade should not be any longer at either edge.
2020 CATERPILLAR 259D3 SKID STEER (A52707)
2020 CATERPILLAR...
UNUSED FUTURE 15" MINI GRAPPLE (A57193)
UNUSED FUTURE 15"...
LINEAR COMPRESSOR FRIDGE / FREEZER COMBO (A57192)
LINEAR COMPRESSOR...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2017 TEREX RL4 4 BULB LIGHT PLANT / GENERATOR (A52707)
2017 TEREX RL4 4...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
