Blade Question
/ Blade Question #1
66cuda
Marne Michigan
John Deere
I知 trying to figure out if this blade would fit a 2017 X570.
Any help you can provide would be great.
Thank you.
/ Blade Question #2
66cuda
Have you decided to keep the X570 after having the problems mulching ?? Or did those problems get solved?
IMO, if that blade isn't the one designed for your X570, I'd suggest avoiding it unless you have a chance to try to fit it up to the X.
Any idea what model lawn tractor that blade was for?
Here is a pic of the blade from jdparts shown for the X570.
/ Blade Question
66cuda
Hi Beenthere,
The cut quality issue was never fully solved. After lots of back and forth between the dealer and even getting John Deere involved no solution was reached. John Deere just said to keep working with my local dealer.
Last summer I ran the deck stock and played around a little. The issue as I see it is that the grass gets stuck up on the roof of the deck and builds up deteriorating cut quality. On my deck the building happens almost immediately, regardless of how wet my lawn is. John Deere and the dealer just kept telling me my grass was too wet. I showed them picture of my half dried out yard in the middle of summer but apparently the parts weren’t dried out were still “too wet”, even during a drought... so I gave up on them. After each mow I use my air compressor with a long wand to try to blow the chunks of grass out of the deck. For the most part it helps, but that farthest chamber is hard to access.
I don’t know what model this blade came off. The seller didn’t list it and only gave the serial number.
I haven’t been able to find a used blade local to me for an x570. On the occasion I do see them, the price seems far to high.
Thanks for sharing that picture!
2017 Mack Semi (A64047)
2017 Mack Semi...
TONUTTI 10 WHEEL HAY RAKE (A64278)
TONUTTI 10 WHEEL...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2019 VOLVO VNL760 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2019 VOLVO VNL760...
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A64553)
2021 Wacker Neuson...
