Blacksmithing, Forge building
/ Blacksmithing, Forge building #11
Flat belts forever!
Got a pic of your uncles shop Mark? I'd sure like to see it.
My lathe uses a flat belt to drive the spindle. Not because it's an old lathe, but because it's a Swiss high precision instrument lathe, and the Swiss know a flat belt is the way to get max traction with low vibration, and yet allow the belt to slip in case of a crash.
And they tell me flat belts are the cat's meow when it comes to driving a power hammer. You can slip the belt for the really slow featherlike taps, and yet apply full power in an instant. For the Bradley I built a framework housing a 3hp 1000 rpm motor and a jackshaft. This framework will be mounted in the rafters of the shop. The jackshaft slows the rpms down to 450 or so at the hammer drive pulley.
Harv,
I didn't quite understand your analogy. Are you telling us you can go out to the shop and make a tool, and that tool changes *** into making love? Could you make me one of those tools? /w3tcompact/icons/grin.gif
/w3tcompact/icons/smile.gif
Dave
I'll see if I can check out the setup - my uncle was a machinist and an old engine collector, before he died. I think the shop is in the same condition he left it. There are a lot of things that could be photographed in there.
Harv!! /w3tcompact/icons/blush.gif/w3tcompact/icons/blush.gif Still experiencing the high of the weekend, I see. Good for you.
I scoped your forge pics out again. What's the long pockets on each side of the firebox for? Looks like a good place to stuff tools or keep stock from rolling or getting bumped off the edge. I was wondering if it had a purpose other than that, or if it was something that was already like that when you found the piece to use.
/ Blacksmithing, Forge building #13
I made a forge when I was in high school from a brake drum. I lined it with refractory clay, which I got from a block & brick supply place. In the center I welded a piece of square tubing with a T off of it. At the bottom of the T I put a shutter and on the horzontal leg I put a heater blower from the junkyard. This let me control the air with the shutter in the bottom and no clinker would fall into the fan. I wish I had a picture of it to show you. Worked good, but alot of smoke with coal.
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A61307)
1992 Talbert 70...
2009 Ford F-750 Manitex 1770C 17 Ton Straight Boom Crane Truck (A59230)
2009 Ford F-750...
