Blacksmithing, Forge building
/ Blacksmithing, Forge building #1
knucklehead
Platinum Member
Maine
1979 Ford 1700, 2001 L3010 Kubota
Hey
Anyone build a forge? Anyone got a hot (!!) setup for someone who doesn't want to make it a vocation, but would like to fool around with some simple stuff (re-pointing wood hooks, twisting and bending stuff for fun and utility), then maybe try welding, or forging some blades?
I got a couple old 20" truck brake drums, and a few odd pieces of 2" pipe & fittings. I've seen drawings of home-made forges used with hair dryers blowing through pipe, up into the brake drum. I've seen people 'smithing with a gas torch for heat, but it seems expensive. I've seen tray-type fire boxes, with sheetmetal hoods.
I'd like to get some ideas for a handy, inexpensive, beginner type setup that could be assemdled with standard stock and pieces. I'd also appreciate advice, and maybe websites, or books if neccessary. Blacksmithing seems like more of a felt thing than a thing one reads from a book, but all info would be glady accepted.
I'd also like info on what type of simple tools to have, fuel to use, and what types of steel - mostly cold rolled, standard stuff? I've seen a lot of shops, some active, some museum type displays, and there's a million tools hanging around the forge, and various vises, etc.. Anyone out there doing a lot of forging with a brake drum forge, and a couple long handled tongs, a hand sledge or big ball pein hammer, a piece of railroad track, and a plastic bucket full of water, or is that too crude?
I know there's a couple of you out there........
/ Blacksmithing, Forge building #2
I've been playing in the beginner blacksmith arena and have a few suggestions to offer. Any method that heats steel to bright red/orange is a good one. If you like coal, go for it! Getting a work area setup with the anvil or track at nuckle height is most important. Watch a smith work and learn how to swing a hammer without getting hurt. Scrap steel dumpsters are a fantastic things behind most fabricators' shops. Don't be afraid to ask, they don't get much for it. Lastly, for a beginner, once the hammer swings, its hard to regain the shape that you started from. Oh, and firebrick can be found lying around too. SteveV
/ Blacksmithing, Forge building #3
Hi Mark,
Check out these sites:
<A target="_blank" HREF=http://www.reil1.net/Forge1.shtml>Ron's Forge page</A>
anvilfire
Ron's forge page in particular has plans for building low cost forges.
The anvilfire site has an active group of folks who can answer any questions you have about blacksmithing. Check out the guru's page.
I haven't used any of the plans yet, but I've been doing a lot of reading in preparation. A blacksmith shop next to my machine shop is on my wish list for retirement.
HTH,
Dave
Thanks, guys - I wondered if you'd see this, Dave. I'm coming close to building the pole barn/shed/shop, and I want to consider options in planning. I've always wanted to try this.
/ Blacksmithing, Forge building #5
You might get a kick out of this pic, Mark. It's a Bradley 50lb power hammer (blacksmith's hammer). Pic is of the hammer as received, with a 80 year accumulation of coal dust and grease. I've since restored and painted it John Deere green. It's awaiting the completion of the blacksmith shop.
Flat belt pulleys! You gonna run that with a flat belt off yer tractor? My uncle got my grandfather's "shop" and set it up in his garage - all flat belt shafting and a big old motor.
/ Blacksmithing, Forge building #7
Now you need to find an old hit and miss engine to run it.
/ Blacksmithing, Forge building #9
I just spent most of the day running my version of the Reil EZ Burner. I've been through just a little over one LP cylinder since building it last spring, and I'm very pleased with the little forge.
Before building the forge, I had done a little forging mostly on very small stock, using propane torches or oxy-acet for the heat source. Worked okay. Enough to make me want something better.
One warning, this is one of those addictive things. You can start with some source of heat, a large steel object for an anvil, a hammer, and a pair of pliers or vise grips. But then you will NEED more. The good news is, you can make a lot of it. My projects for the day were all tongs and chisels.
Steve
I'll see if I can check out the setup - my uncle was a machinist and an old engine collector, before he died. I think the shop is in the same condition he left it. There are a lot of things that could be photographed in there.
Harv!! /w3tcompact/icons/blush.gif/w3tcompact/icons/blush.gif Still experiencing the high of the weekend, I see. Good for you.
I scoped your forge pics out again. What's the long pockets on each side of the firebox for? Looks like a good place to stuff tools or keep stock from rolling or getting bumped off the edge. I was wondering if it had a purpose other than that, or if it was something that was already like that when you found the piece to use.
/ Blacksmithing, Forge building #13
I made a forge when I was in high school from a brake drum. I lined it with refractory clay, which I got from a block & brick supply place. In the center I welded a piece of square tubing with a T off of it. At the bottom of the T I put a shutter and on the horzontal leg I put a heater blower from the junkyard. This let me control the air with the shutter in the bottom and no clinker would fall into the fan. I wish I had a picture of it to show you. Worked good, but alot of smoke with coal.
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63688)
2017 Cadillac...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
207923 (A63290)
207923 (A63290)
iDrive TDS-2010H...
Rhino HPHD (A64127)
Rhino HPHD (A64127)
