Black nob
/ Black nob #1
Robbiedeanvick
Nacogdoches Texas
Kubota B2400
Hello I just bought a 2001 Kubota 2400 diesel . I have one question below the seat there is a black nob says open close . What does it open and close ? Please let me know .:dance1:
/ Black nob #2
I think you are talking about the pressure control knob that controls the three point lift. If you lower an implement with this valve all the way open the implement will drop like a rock to the ground. If you try to lower an implement with this valve all the way closed it won't lower at all. You can play with it with an implement attached to get the setting correct.
/ Black nob #3
What "whistlepig" said. ↑↑
That said.... :welcome: to the forum.
/ Black nob
Thanks I have a five foot bush- hog behind it and a front loader I will try it and thank u again
/ Black nob #6
Be careful. Knob all the way open will slam the bush hog to the ground. Better to start knob all the way closed. Tiny steps.
/ Black nob #7
The knob will also lock the implement in the up mode for transport.
Also used to trouble shoot the piston seals in the 3pt.
If you raise the implement and turn the knob closed, and the implement still falls, then the piston seals are leaking.
/ Black nob #8
This!
In fact, it's a really good idea to lock the implement in the up position during transport. Some manuals will warn you that damage can occur if you fail to do so.....probably depends on how the system is made, and where the lock is in the system.
/ Black nob
Thank's to every body for the help ! U all was right played with it this evening. This is my first tractor I'll probably will have a lot of question on down the road once again THANK U ALL VERY MUCH .
/ Black nob
Mr. J J I have another question for u my Kubota has power steering how do u check the fluid & it's a auto M where or how do u check the fluid .
/ Black nob #11
There is no separate reservoir for power steering fluid. The power steering uses the same UDT fluid as the 3pt hitch and the HST transmission. Maybe yours is different but I don't think so.
/ Black nob #12
I don't have a separate reservoir for the power steering either. It runs off the UDT fluid in the transmission.
/ Black nob #13
Do you have a separate tank for the PS fluid?
/ Black nob
JJ I don't know . I didn't get no manual with it to show me or tell me any think . Just to be on the safe side I just put it in the shop to have all service. The person had it be for me told me he has never had it serviced just the oil changed. And I ordered me a manual for it
3096 (A63117)
3096 (A63117)
Unused 2023 Monroe Tufline TW693222 12ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
2017 International WorkStar 7500 T/A VacCon VPD4211 Combination Sewer Jetter Vacuum Truck (A66736)
2017 International...
2015 CHEVROLET SILVERADO CREW CAB PICKUP TRUCK (A66091)
2015 CHEVROLET...
2018 Ram 1500 Reefer Meal Delivery Truck (A64556)
2018 Ram 1500...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
