BL4690B Backhoe Performance
/ BL4690B Backhoe Performance #1
vulcancowboy
Duncannon, Pennsylvania
Kubota L3400 HST
Finally got an opportunity to put the backhoe to the test. I dug a 60' x 24" trench and dug out a few stumps. The hoe seems "sluggish", i.e. on other backhoes I have run, I can "shake" the bucket to remove dirt and debris that didn't fall out during a normal dump. This hoe is not snappy enough to do that. I'm wondering if the hyd. filter (this unit has a PTO mounted pump for the BH, with a separate filter) could be restricting the flow. The hyd. level in the tank is correct. Or maybe this is "normal" for this type of BH.
Any advise is appreciated.
2003 Odyssey Lextra 2502 Pontoon w/ 2009 Bagg Boat Trailer (A62613)
2003 Odyssey...
2013 Keystone Springdale Camper (A62613)
2013 Keystone...
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
Trimble Automated Steering GPS system (A64126)
Trimble Automated...
2006 PROCO 130BBL (A65643)
2006 PROCO 130BBL...
