BIY Rear Remotes
/ BIY Rear Remotes #1
HawkinsHollow
SE TN
Branson 3015R
Hello all. I am interested in putting together my own kit to install rear remotes on my 2019 Branson 3015. I have a freind that can get CHEAP hydraulic hoses and fittings, so all I would need to buy retail is the valve. I am a hydraulic newbie, although I was able to install a diverter valve for my grapple, with LOTS of help from my locate Hydraulic Supply store. Can anyone tell me what I would need to make my dreams a reality? Or point me in the direction or a thread that might? Thanks!
/ BIY Rear Remotes
Finding a lot more info on here now that I am diving in deeper. If you have any nuggets of knowledge I will still take them though.
/ BIY Rear Remotes #3
I've bought a lot of hydraulic stuff off Surplus Center. They'll definitely have the valve you need.
Update this thread when you get yours built and installed.
/ BIY Rear Remotes #4
Last I checked the Branson remotes were reasonably priced. They integrate into the tractor well.
But if you do it yourself, the line that goes back to the very rear of the transmission case is the loader's power beyond (on 20/25 series, I'm assuming yours is similar). You can use that. If you use a valve that does not have PB make sure the tank port is rated for full system pressure.
