Big drill bits
/ Big drill bits #81
My HF drill press didn't scratch them. Slow, fast, oiled, didn't matter, it was not able to provide the torque on the slowest setting with the belt as tight as I could get it.
This is 3 pieces of 3/8" steel that I used for building my pallet forks for my bobcat. It took 40 minutes to get through like this: http://i.imgur.com/pQRDLoy.mp4
With my HF cheap drill press, I can drill a 3/8" thick plate on the slowest belt settings, and can drill a 1 1/2" hole using a Milwaukee metal hole saw in about 5 minutes using "WestLube" lubricant and keeping the shavings cleaned out of the hole.
In your video, if your drill does not have a slower speed and you are slowing the speed down with pressure pushing down, looks to me that you need to readjust your process, just a thought...
Also, with my drill press I can keep adding the lubricant while drilling the hole, and the HF cheap drill press forces me to use medium to light down pressure (does not create a lot of heat).
I would also only drill through all 3/8" plates with a 1/4" drill at once, and then drill each 3/8" plates separately with the hole saw.
Good luck, KC
/ Big drill bits #82
A friend just bought an iron worker for more than some people pay for a house. Same guy who got my Hougen. I'm just helping him put a laser target on it. He showed me something like a 1" hole slug from 1" material. AMAZING!
/ Big drill bits #83
^^^ Seeing made me a believer... just put out slug after slug.
/ Big drill bits #85
/ Big drill bits #86
Interesting inserts LD, got a link for the tool they fit? MSC's no help... Steve
(BTW, don't think I'd wanna free-hand it :=)
/ Big drill bits #89
No I dont have any links. I dont actually have a set of spade bits, but several places I have worked always had them. We only ever had to order replacement inserts, never an arbor. So????
/ Big drill bits #90
/ Big drill bits #91
FJ's machine weighs just a bit more than my Case 580B; I for one wouldn't wanna see any pins smaller than 1-1/2" - my hoe has 1-1/2" pins EVERYWHERE on both loader and hoe, except for the main hoe bucket pivot which is 1-3/4". Never thought any of 'em was too BIG... Steve
/ Big drill bits #92
The bucket pivot on my 310 was also a 1-3/4.
2001 Sea Breeze RV (A62613)
2001 Sea Breeze RV...
3269 (A63117)
3269 (A63117)
3ft Metal Rooster (A65583)
3ft Metal Rooster...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
John Deere 660 Hay Rake (A65640)
John Deere 660 Hay...
Pemberton Inc 416469 72in. Loader Forks and Frame (A64194)
Pemberton Inc...
