Big Barn’s Retirement Farm Shop
   / Big Barn’s Retirement Farm Shop #4,571
Mine is rechargeable with permanent batterys. I need to keep it facing a light while being stored or there isn't enough of a charge to operated the auto dimming.
   / Big Barn’s Retirement Farm Shop #4,573
My Miller helmet has a "low battery" warning light when I first turn it on. I've only had to replace the battery once in since I bought it 15 years ago, mostly because of lack of use. Mine takes a AAA battery. I keep it on the gas cylinder. I make it a habit to only hang my helmet there after I turn the gas off. It's my way of making sure I don't lose a full tank because I forgot the valve.
Good practice for remembering to turn gas off.
My lids have low battery indicators but they either don't work or I failed to notice them.
Surprisingly two helmets actually use the SAME SIZE coin battery. (C2450). Things like that rarely happen to me.
   / Big Barn’s Retirement Farm Shop #4,575
Good idea as I have inadvertently emptied a few bottles. My reminder is that I always clean up my torch and hoses. When I do that the tap gets shut off.
   / Big Barn’s Retirement Farm Shop #4,576
Spalted always gets attention.
I would love that lathe. I only have an older Delta where I have to move belts to change speed. I've been tempted to change it over to a variable speed system.
Variable speed is sweet! I was so impressed I got the Nova drill press as well and sold off my belt driven tools.
   / Big Barn’s Retirement Farm Shop #4,577
I realize the above response was about a lathe, but.
We have an old (OK, not REAL OLD, about 40 years) Delta or maybe Rockwell drill press. There are three sets of sheaves, with RPM capability of something like 200-5,000 (may be a bit of exaggeration there, just going off memory from maybe 10 years ago which is the last time I really looked at it). It's VERY simple and quick to change - an L-shaped handle holds the motor in place, just loosen that and you can change one or both belts in 10-20 seconds. Unless I were an 8-hr x5-day drill press operator, doing jobs for 5 minutes at a time and everyone required a different speed, I can't possibly see the payoff of a VFD over a simple mechanical setup.
   / Big Barn’s Retirement Farm Shop #4,578
I do similar...and check that the gas is off like 15 times while cleaning up...:D
   / Big Barn’s Retirement Farm Shop #4,579
I guess it was time. Today I got flashed using my auto dark welding helmet and realized it needed batteries. And the reason I was using this helmet was because I was too lazy to replace batteries in my other lids.
So today I took the time to replace batteries, inner and outer lenses where necessary and generally clean my helmets.
DONE! I really don't do a lot of welding so I should be good for another 5 or 6 years.
Which helmet you prefer? Our old Millers (14 years old) gave up. So did my helmet I bought.
I ordered a cheap, smaller window Miller online for only $86. Waiting for it to come in. Had good reviews.
I really like my $100 (+ or-) Weldcote.
Lightweight and by far the most comfortable I have ever used.
Large viewing area and good clarity.
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A52576)
2018 HINO 268 NON...
2025 New/Unused Wolverine 72'' Skid Steer Ripper (A51573)
2025 New/Unused...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
Ingersoll Rand TS5 80 Gallon Air Compressor (A51573)
Ingersoll Rand TS5...
