BH Stabilizer droop
/ BH Stabilizer droop #1
Frankenkubota
Elite Member
Carthage NC...Deep in the woods
Kubota MX 5800, SkidPro 4 in 1, Ratchet rake, SkidPro pallet forks
I did this a while ago but thought it was so obvious, i didn't post it.
My BH is kept from drooping by a big hook made of heavy duty steel that grabs a big pin.
I was going to weld up a similar solution for me BH stabilizers. They droop and, if you don't pay attention, they turn into bat wings that will either self destruct of tear something up.
Duh......
Decided to use a left over piece of strap they used to secure my trusses on the delivery truck, convenient, cheap and, so far so good.
/ BH Stabilizer droop #2
Duh......
I use the same type strap for the same purpose,..... but I only use the Shoe Goo for my shoes!
you caught me
i also used needle and thread to secure things but......
When's the last time you tried to thread a needle?
Holy moly, took a long time!
/ BH Stabilizer droop #4
I used to use the same trick to deal with stabilizer cylinder bleed down. It's simple and obvious but I found out the hard way it can cause problems. On one occasion, I must have been in a brain fog. Instead of raising the stabilizers to release the tension on the nylon strap, I lowered them instead. The nylon strap snapped and one of the hooks put a sizable dent in the wall of my steel building! Luckily, I wasn't in the way and the only injury was to my self esteem!
Now, I use a couple of lengths of chain between the handrail and the stabilizer foot pin. I bent the chain hooks so they just slide off if too much tension builds up. They retain the stabilizers but just fall off if I make the same stupid mistake.
View attachment 709705 View attachment 709706 View attachment 709707
i thought i was the only one to make stupid mistakes!
/ BH Stabilizer droop #6
You guys make this all fancy and now I feel like my black bungee is inadequate :eek:
Note though, whatever those black bungees are made of really doesn’t like hydraulic fluid. Use them for hose management on the grapple and one drop from hooking/unhooking and that sucker melts through in about a day.
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
MIRRORS, MARKER LIGHTS, SWITCHES (A64276)
MIRRORS, MARKER...
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
