BH Removal
/ BH Removal #1
BigD23
Platinum Member
Pac. NW
Kubota BX23 TLB
Going to take the BH off my BX23 for the first time...The prior owner had never removed it...The Bota has 200 hours on it...Any tips to help make it go easier? Add lube to any of the removal points prior to/afterwards? Thanks in advance...Hope you all had a nice 4th.
Don
/ BH Removal #2
I presume it is a Kubota OEM backhoe? I'd shoot the attachment pins down with WD40 or the like just in case they have some corrosion.
/ BH Removal
Yes, it's the BT600.
Don
/ BH Removal #4
A "little" spray lube on the jaws and the little slider pin thingy that goes between them helps. Do it on the flattest place you have the first couple of times till you get used to it. I have gotten to the point where I can drop it almost anywhere without worrying about ground flatness, and use the backhoe hydraulics to move it around to line up with the tractor. The FEL is another story.
/ BH Removal
Thanks Bernie...Will save the FEL for another day...Still have a few things to do while the BH is on, but wanted to do some "homework" prior to removing it.
Don
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
2008 DRESSTA TD-15M EXTRA CRAWLER DOZER (A65053)
2008 DRESSTA...
MACDON FD235 - 35' DRAPER HEAD (A64278)
MACDON FD235 - 35'...
2024 BOBCAT T76 SKID STEER (A67148)
2024 BOBCAT T76...
2011 GMC Acadia SUV (A64557)
2011 GMC Acadia...
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
