Better MMM Blades?????
/ Better MMM Blades????? #1
don716
North Georgia
Kubota/ B7500/with 2000 lb winch
I have a B7500 with a 60" MMM from a B7510 turf Special and was wondering if there was a better set of blades for my mowing deck? It mows grass good but I think it could be better.I've sharpened them but I think it could leave a little bit cleanner or neater cut.I've noticed the grass that is throwed out is big or long clippings. Are there blades with a finner cut that will do a better job???,and if so about how much are they?
Donny
/ Better MMM Blades????? #2
Howdy, I just installed a set of Gator mulching blades on my BX1800 54" MMM and thought the cut I got was very good. My observation was the Gator blades chop up grass, leaves etc. to smaller pieces than my factory blades. You can find them for $12-15 apiece by doing a Google search for "Gator blades".
jd
/ Better MMM Blades????? #3
I would suggest a high lift mulching type blade. I have the factory mulching kit for my BX24 54" MMM and it works incredibly well. I can't get over how nice it will mulch the grass and leave nothing behind.
/ Better MMM Blades????? #5
Nice to hear about Gator blades. I think my 7510 60" mmm cuts like a piece of junk. I hope it's just the blades. I am going to chain up the mmm next spring too.
/ Better MMM Blades????? #6
I have the rck60b_75b from a Turf Special on my B2410. Have to say it does a great job, BUT it has to be set up properly. When I first put it on I had a hard time getting a nice even cut until I was able to get it properly leveled. It's a bit tricky and a bit of trial and error and several times adjusting on a flat concrete surface then back out to try it before you get it right. Make sure it is absolutely level side to side and slightly lower in front than rear...about 1/16 - 1/8" I find best....but anything from level to 1/2 inch lower in front works for me. Note....I am measuring the blade itself, not the deck, and about at mid height... a good way to scuff up the wrists but is a must. Measuring the deck lip instead of the blade is not accurate enough.
Added this edit after realizing I don't know if you have a suspended deck (rck60b_75b) or rck60_24b. I've not used a 24b so it might have more to do with the gauge wheel settings but I'm sure the end result must need to be similar.
I haven't read up here in a while, stopped by to see if anyone has seen a Gator Mulcher that fits these smaller spindle decks....apparently not, must still have to cut your own spacers. Guess I need to call Oregon and ask. Hard to imagine that with all the BX machines out their (which is basically what a Turf Special deck is) they have not made a direct fit, unless I'm not up to speed on it yet. After two summers now I'm at the point I have little steel left on the original blades. The OEM high-lift is a bit pricey in my opinion at $75 a set local.
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
213087 (A64276)
213087 (A64276)
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A65053)
2021 CATERPILLAR...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
Wolverine MCB-11-48W Mini Skid Steer Bucket (A62679)
Wolverine...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
