Best way to get diesel into the tractor?
   / Best way to get diesel into the tractor? #61
One of the reasons I love ground level fueling
   / Best way to get diesel into the tractor? #62
That's what I do. Exactly. Same container and same spout. I do put a piece of padding on the hood so it doesn't eat up the paint so bad...wish I'd done so years ago.
   / Best way to get diesel into the tractor? #63
   / Best way to get diesel into the tractor? #64
I got a 12v pump, hose, and nozzle kit from NT. Was pricey but works a charm mounted on a 55gal drum with a little AGM battery.
   / Best way to get diesel into the tractor? #65
To fill my lawn mower I put a T in the gas line on
my old Dodge pickup with a ball valve and a long
hose. When I needed gas for the lawn mower just
push lawn mover over my truck start truck open
valve and walla gas tank full.
For diesel I have these 2.5 gas oil plastic cans and
will be using them as they come with the oil and a
lot lighter than 5 gal. I have no problem lifting the
5 gal can of diesel to put on top of the hood and I
also have a battery operated pump where I put the
5 gal of diesel on tire and let the pump work.
willy
   / Best way to get diesel into the tractor? #67
I bought a "Shaker hose".
Flotool Shaker Siphon - 6Ft., 3.5 GPM, Model 10801
I put the fuel can in the loader bucket, raise it above the tank and siphon fuel into the tractor.
Someday I'll have a 30 gallon tank and put it overhead in the shed, so that I can just turn on the valve and it will run into the tank.
   / Best way to get diesel into the tractor? #68
You can do it cheap and do it again in few years, or you can spend $250 - $350 and do it once!
Each to his own.
   / Best way to get diesel into the tractor? #70
The easyest way is to get somebody else to do it;)
willy
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
UNUSED FUTURE MINI QUICK ATTACH PLATE (A54757)
UNUSED FUTURE MINI...
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
KING CUTTER 6' FINISHING MOWER (A54756)
KING CUTTER 6'...
(7) UNUSED IRANCH PORTABLE DUMP HOPPERS (A54757)
(7) UNUSED IRANCH...
