Best snowmobile studs
/ Best snowmobile studs #1
lawnduster
Central NH
CAT 966, Case 580
what are the best snowmobile studs for trail riding, have a 05 SD GSX 380 and want to stud it, how much do they cost, can I do this myself?
/ Best snowmobile studs #2
Carbide, pricey but then again you don't have to do them every year either. Yes you can do them yourself but you will need a few tools.
/ Best snowmobile studs #3
Any of the major brand studs are pretty high quality. For a 380 Fan, you would only need 48 down the middle since there isn't much horsepower there. The track lugs on that machine are so short (less than 1 inch) that you may not even need tunnel protectors, although Ski Doo recommends them. The factory recommends Woody's studs, and they may be your best bet.
/ Best snowmobile studs #5
They have several different models to choose from. I see you're in Central NH. I would call Jack Willey's Lakes Region Supply in Tilton and talk to them. It should be less than $100.
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
725 Gal Poly Tank on Skid  (A62679)
725 Gal Poly Tank...
(4) ASSORTED TIRES (A62613)
(4) ASSORTED TIRES...
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
