Head gasket repair sealant
   / Head gasket repair sealant #1
RidgeTopWVA
John Deere 4400
Does anyone have any recommendations of a reliable head gasket repair additive that you pour into the radiator to seal a leaking head gasket in a Toyota if so what is the best one what do you recommend ?I know the best way for a fix is to do a teardown or engine replacement but that is cost prohibitive at this time. My vehicle is a Toyota Tacoma 4 cylinder 2.7 litre and the leak is coming out of the exhaust .
Thank you
   / Head gasket repair sealant #2
There is NO such of a repair in a can fix. The only way to fix the issue is to fix it the correct way. Anything else is risking the whole engine and cooling system.
   / Head gasket repair sealant #3
Unfortunately those stop leak products are also known for stopping up radiators too.
   / Head gasket repair sealant #4
A head gasket replacement does not REQUIRE an engine teardown if all you want is to replace the gasket. There are gasket sets for doing a top end teardown without going "all the way". Be prepared to spend a day in the shop but the job is generally not that bad. The problem is all the accessory stuff you may have in the way on these newer cars.
   / Head gasket repair sealant #5
I've used Rislone on a Volvo where it leaked externallyat the joint of the head and block. First application was prior to 2010 and lasted until I needed to replace the rad and cleaned the system. Second treatment lasted until I totaled the car two years ago. On my Ford 460, prior to 2010, there was a slow leak where I was unable to find it anywhere, but it did put out a bit of condensation(?) when first started. I needed to add water frequently, considerring I didn't drive it much. After the treatment I only add water once or twice a year.
That is what I am planning on doing later this week.
Thank you for your advice much appreciated
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Dodge Charger (A56859)
2447 (A60432)
2447 (A60432)
FENCE PANELS (A58214)
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
