Rotary Cutter Best rotary cutter for the $$$$
   / Best rotary cutter for the $$$$ #31
Don't have a tractor yet, Most likely going with a Kioti CK 3510 HST. Kinda just trying to get opinions on what rotary cutter to go with when I purchase the tractor. I do have a fair amount of the 1-2" saplings and some briars/brush to clear out initially but after that it should mostly just be mowing the fields and maintaining them. I just don't want to spend a 1000 bucks on something now and a year from now wishing I had spent that extra 500-1000 bucks on a better cutter. My local dealer I know carries land pride and bush hog brand cutters. I am going to pay him a visit soon to drive the tractor again and check out some implements.
I just bought a Woods BB48X for my Kioti CK27. I wanted a 5 ft machine but after looking at my PTO HP and it was only rated for 21 hp. Since i have a HST transmission you lose hp from the engine to turn the pto. So look at what size pto implements you want to use and size tractor pto hp accordingly !
Since i am cutting around trees in the forest i needed a small width cutter....it works just great for what i need to use it for. I may have bought the EA 60 inch extreme duty cutter, but my tractor wouldn't handle it.
   / Best rotary cutter for the $$$$ #32
What’s with the ”mines bigger than yours” post, it’s still a regular old gearbox. Even if someone felt then need to buy OEM, the most you’d be out is probably around $600 and a little time. That’s absolute worst case scenario, though I’ve never known anyone that actually had to replace a gearbox on a brushhog.
I've replaced the gear box on my Landpride 6 ft rotary cutter three times now. I also use it for clearing land and will cut anything I can drive over. It's a pain in the but to replace, especially when the stump jumper gets busted up too, but it's all doable. This is why I recommend buying a brand that you can get parts for, everything breaks, it's just a matter of how willing you are to break it!! :)
   / Best rotary cutter for the $$$$ #33
Ok i finally destroyed my 6' Sunshine brush hog by Modern Mfg. One of the bolts on the gear box sheared and broke the steel on the aft side of the deck. I have a wooded area I mow that is pretty rocky and can't see the rocks so it takes a lot of abuse. What would be a good suggestion for a 6' rotary cutter the can take the abuse. Blades are expendable i understand that. I have a Mahindra 485 DI that has 2067 hours on it but still runs good. Any suggestions?
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
LOT OF PALLET RACKING W/ WIRE MESH SHELVING (A52708)
LOT OF PALLET...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
HELI 5K FORKLIFT (A58214)
HELI 5K FORKLIFT...
2014 Chevrolet Impala LT Sedan (A56859)
2014 Chevrolet...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
