Rear Blade Best Rear Blade ?
/ Best Rear Blade ? #22
I'm sure that <A target="_blank" HREF=http://www.monroetufline.com/>Monroe Tufline</A> would be able to tell you your closest dealer. I know we have one very close to us here in Edmonton, AB....so they do retail in Canada. Good luck. If you get hold of them, I'd be very interested to know the CDN $$ you are quoted.
Kevin
/ Best Rear Blade ? #23
knight9 - when ofsetting the blade swinging it around is actually easier - you just use the "short" end to clear the tires as you swing. Mine can swing either way and when not offset I have to have it rasied at kust the right height in order to clear the tires. If it were offset I'd have an extra foot of clearance on the "short" side.
/ Best Rear Blade ? #24
Gerard,
<font color=blue>you just use the "short" end to clear the tires as you swing</font color=blue>
...ok, then that must be blade specific because IF my blade was capable of being offset, it would depend which way I had it offset as to whether or not I could turn it around. My Farm King blade will only turn around one direction. It will completely swivel around 180 degrees, but can only do so one way. Apparently that is not always the case, so I guess the next issue would be to ensure that any blade that can be offset can be turned around either way.
Thanks,
Kevin
/ Best Rear Blade ? #25
yep, that makes sense - I can go 360 deg and turn it in either direction, may not be the case for all.
/ Best Rear Blade ?
The cost of the Blade is a bit high. I called ACGroff, a dealer in New Holland, Pa today. The cost of a GB1-60 which is a 5ft blade is $599.00. The blade is the best blade, that I've seen so far. I defend John on that point, and that's what I asked for. I just can't put $600 in a blade, so my search has gone to a good cheaper priced blade. I'm assuming that Bush Hog, Woods, and Land Pride are back in the running. The price is between $300-$400. I still want good quality, and durability. Thanks to all who have tried to help. Kent
/ Best Rear Blade ? #27
<font color=blue>...cost of a GB1-60 which is a 5ft blade is $599.00...</font color=blue>
/w3tcompact/icons/blush.gifWow.../w3tcompact/icons/blush.gif
The model pictured at the NY Farm Show was an 8' about $8xx..
Call around and don't depend on one solitary price quote.../w3tcompact/icons/wink.gif
/ Best Rear Blade ?
Will do John, I'm was looking for someone close to home. I could save by picking it up myself. ACGroff is in New Holland,Pa, which is about 1 hr from me. I sent email to the company for info on other dealers in the area. I'm still hoping, that looks like quite a blade. Thanks Again. Kent
/ Best Rear Blade ? #29
If you don't already subscribe to Lancaster Farming, it might be a good idea for the ads. I've got some deals on impliments in PA that were worth me driving from WV. They have the largest equipment related ad section for your area.
That and some patience on your part could get you the blade you want at the price you want.
/ Best Rear Blade ? #30
I inquired about Monroe's boxblades a few weeks ago. The prices I was quoted are at work, although I think I posted them here somewhere, but they were much more than I expected. They were considerably more than Woods, LandPride, etc..
Of course the dealer I was talking to got his prices from the a distributor in New Holland PA. Maybe the middleman pushed the prices up. /w3tcompact/icons/smile.gif
/ Best Rear Blade ? #31
I agree the Monroe Tufline may be the best for compact tractors. I own the 5 ft tufline blade (weight 386 lbs). The price was $500, so Monroe's are a bit pricy; but you will not be able to bend the blade.
/ Best Rear Blade ? #32
<font color=blue>...you will not be able to bend the blade. ...</font color=blue>
You're right Joe... these Monroe-Tufline units are very underrated... even if someone pays an extra $50-100. on day one... I think these blades will last for years and years... excuse the "pun"... but these blades are Tuf... /w3tcompact/icons/wink.gif
/ Best Rear Blade ? #33
Re: Best Rear Blade-Monroe-Tufline
Front View of Monroe-Tufline rear blade
(see attachment)
/ Best Rear Blade ? #34
I have a 6' Tuffline GB with hyd. angle and paid $650. I recently dug an 18-24" deep ditch 200' long to install an electric line. To accomplish this task, I manually tilted the Tuffline blade to its maximum tilt and then using the hyd. angle I was able to almost have the blade stand upright at 75 degrees. With my NH 1720 4x4 pulling, it really tested that Tuffline blade. Tuffline would be my 1st choice again.
/ Best Rear Blade ? #35
Would you mind sharing where in Va you purchased your Tufline blade? I'm near Roanoke, Va and the only dealer Monroe told me about didn't seem to want to sell Monroe's stuff. His prices were very high. I'd like to find another dealer reasonably close (few hours drive) to get a quote from.
Thanks,
Brad
/ Best Rear Blade ?
Thanks Gentlemen, You've all done a great job of giving me food for thought. I need to balance price, and quality. Much like everyone else here. If I can find a used blade, I'd jump at it for the right price. Thanks again for all the great feedback. Kent
/ Best Rear Blade ? #37
Brad,
I purchased my Tuffline blade from Surry Equipment in Surry VA. 1-800-562-3568. Ask for David in sales.
Pat
/ Best Rear Blade ? #38
Thanks Pat. I appreciate the information. But Surry is probably a little too far to drive. It's about 5-6 hours from me. I lived in Richmond until about a year ago, it wouldn't have been too far from there. I guess I'm stuck dealing with the expensive local dealer. /w3tcompact/icons/sad.gif
--Brad
/ Best Rear Blade ? #39
All indications are that the Monroe is top-of-the-line and would be best suited to daily or commercial users who can justify the 'premium' cost.
I've been considering a Land-Pride back blade. Originally I was leaning toward the lower end units due to the ability to swap balde for rake on the same carrying chasis. I thought this would be a good way of saving a few bucks!?
Now I'm really looking towards the heavier units and the optional hydraulic tilt and angle.
I'll be using with a NH 35D. Usage will be maintaining 1400' of gravel driveway.
Qusetions:
Am I asking for too much on the 35 HP tractor ??
Any other recommended mfrs to consider ??
Any other thoughts ??
/ Best Rear Blade ? #40
I don't know what size you're looking at but a 35 hp should be able to handle a 7 footer with no problem. (I have a 7 footer on a 26 hp bota and wouldn't want anything smaller) Only time you have to be a little careful is if you offset to one side. Too big a load out on the end and I guess you could twist/bend one of the lower link arms on the 3 pt but I haven't had a problem yet. You definitely want to cover your tires and with a 6 footer angled to the max you might not do that.
