Best oil for Branson 4220i?
   / Best oil for Branson 4220i? #1
branson owner
branson 4220i
what is the best type (weight) oil to use in the Branson 4220i? The oil filter said use 10w30 for summer use.
   / Best oil for Branson 4220i? #2
I'd use Rotella-T 15W40 diesel oil. I use it for everything.
JayC
   / Best oil for Branson 4220i? #3
Why not a 10w40 or a 5w40 year round?
Thanks JayC and Transit. I was able to get up with my dealer (which had been on vacation). He said to use Rotella-T also. I talked with another dealer before and he said us 10w-30.:) Now that I have the filter off it reads 10w30 (summer season use 30 oil). The Korean writing was top side on the tractor (my luck :laughing: ) I think I going to go with the Rotella-T. Thanks for the feed back.
   / Best oil for Branson 4220i? #5
i don't see too many 10w40 C rated oils.. 5w40 and 15w40 and 10w30 yes.
to the OP...I'd go with manufacture weigth specifications in your temp range
soundguy
thanks sound guy. I am using Rotella-T1 which is 30w for this summer. Then I will get back with my dealer about using Rotella-T 15w-40 for winter. The Rotella-T 15w-40 help with the sulphur in the HWY fuel (don't use enough to get NonHwy fuel). The problem I was having was the service manual just said higher than CC. It wasn't until i got the oil filter off that i could read all the info on it. Rotella-T or T1 are both good. It was much easier when i had it serviced but Times are hard.
   / Best oil for Branson 4220i? #7
where are you still getting high sulphur fuel.. I was under the impression that even non taxed/dyed fuel was LSD or ULSD...
soundguy
   / Best oil for Branson 4220i? #8
   / Best oil for Branson 4220i? #9
must be a regional thing. that product, nor are 10w30C rated oils commonly available on the shelf down here in florida. if you want a diesel oil down here, you can get 30w, 40w, 15w40, or 5w40.. anything other than that is scarce...
soundguy
Shell T5 everyday at wally world or TSC..but yea i see what your saying other then that harder to find.
- Shell Rotella T5 Synthetic Blend Technology
Yep all ULSD here in MI 15 PPM..
   / Best oil for Branson 4220i? #10
No kidding your TSC don't stock it?
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
2006 International 9400i (A53472)
2006 International...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
