Best oil for Branson 4220i?
   / Best oil for Branson 4220i? #1
branson owner
branson 4220i
what is the best type (weight) oil to use in the Branson 4220i? The oil filter said use 10w30 for summer use.
   / Best oil for Branson 4220i? #2
I'd use Rotella-T 15W40 diesel oil. I use it for everything.
JayC
   / Best oil for Branson 4220i? #3
Why not a 10w40 or a 5w40 year round?
Thanks JayC and Transit. I was able to get up with my dealer (which had been on vacation). He said to use Rotella-T also. I talked with another dealer before and he said us 10w-30.:) Now that I have the filter off it reads 10w30 (summer season use 30 oil). The Korean writing was top side on the tractor (my luck :laughing: ) I think I going to go with the Rotella-T. Thanks for the feed back.
   / Best oil for Branson 4220i? #5
i don't see too many 10w40 C rated oils.. 5w40 and 15w40 and 10w30 yes.
to the OP...I'd go with manufacture weigth specifications in your temp range
soundguy
thanks sound guy. I am using Rotella-T1 which is 30w for this summer. Then I will get back with my dealer about using Rotella-T 15w-40 for winter. The Rotella-T 15w-40 help with the sulphur in the HWY fuel (don't use enough to get NonHwy fuel). The problem I was having was the service manual just said higher than CC. It wasn't until i got the oil filter off that i could read all the info on it. Rotella-T or T1 are both good. It was much easier when i had it serviced but Times are hard.
   / Best oil for Branson 4220i? #7
where are you still getting high sulphur fuel.. I was under the impression that even non taxed/dyed fuel was LSD or ULSD...
soundguy
   / Best oil for Branson 4220i? #8
   / Best oil for Branson 4220i? #9
must be a regional thing. that product, nor are 10w30C rated oils commonly available on the shelf down here in florida. if you want a diesel oil down here, you can get 30w, 40w, 15w40, or 5w40.. anything other than that is scarce...
soundguy
Shell T5 everyday at wally world or TSC..but yea i see what your saying other then that harder to find.
- Shell Rotella T5 Synthetic Blend Technology
Yep all ULSD here in MI 15 PPM..
   / Best oil for Branson 4220i? #10
No kidding your TSC don't stock it?
3in Poly Pipe (A49461)
2014 MACK GU (GRANITE) (A50854)
2014 MACK GU...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
