Buying Advice Best mulching MMM for SCUT
   / Best mulching MMM for SCUT #31
Hey thanks Axel.
That’s the information I needed.
One other question you state you can mow in high range does that include mowing up hill?
I plan to test one at the dealer.
I wonder if MF leases the GC1700s?
   / Best mulching MMM for SCUT #32
Diesel,
I can't mow up my hills in high gear because they are very steep hills. Most people wonder how I can cut them much less in what speed.
   / Best mulching MMM for SCUT #33
AxleHub or any other person, with the MF mulching MMM can you post some pictures of the under side of the deck and blades/spindles?
   / Best mulching MMM for SCUT #34
You'll need to get pictures from someone else as my deck is already on.
But to describe the 2315 deck,
It has 3 rear hidden rollers
1 exposed front roller
4 exterior wheels
It has 3 spindles and each spindle drives a smaller blade mounted high and a large blade mounted low for a total of 6 blades.
Each spindle grouping has its own metal cutting chamber separate from the other 2. Unlike normal decks, there is no sharing of grass pathways. There is no plastic or rubber on the underside of the deck.
The outside total width of the deck is 55.5 inches and the bottom edge of the deck is heavy rolled edge Steel. There are no chutes on any side of the deck. Blades are very close to the bottom of the edge of the deck and allow you to trim very close to objects both horizontally as well as vertically to the edges of the deck. Weight is 235 pounds. You can cut from the right or from the left and not have beds or gardens or houses or people hit by rocks or sticks, or blown grass etc..
   / Best mulching MMM for SCUT #35
4 exterior wheels
I quit searching on TBN and went to google and found this on TBN. Does it looks like a MF 2315?
http://www.tractorbynet.com/forums/...ur-service-video-post4524065.html#post4524065
   / Best mulching MMM for SCUT #36
That is an older version. Its a fair amount different when it comes to rollers. And the deck is similar but not the same around any of the rollers. I'm guessing it is one from the early 2000s.
   / Best mulching MMM for SCUT #37
Are the blades similar?
Pickup Truck (A59230)
2014 JCB 930 (A53317)
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
Sprayer Specialties XLRD 1250 Sprayer (A59814)
Sprayer...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
Case 2390 Tractor (A59814)
Case 2390 Tractor...
