dieselscout80
Elite Member
Diesel,
I think you are focused way too much on speed. If you are cutting step slopes, you'll have to lighten up on the foot pedal on any deck choice because you take more power to go up steep slopes. . . . Not to mention you were talking about 6 inch tall grass. But that would be no different with any normal lawn tractor or Zero turn.
Next, if you have "nice lawn" you should be cutting it when it's 5 inches or less (technically 4.5 inches to leave 3 inches). Which is why I gave you two quite different examples.
Next, we use absolutely no fertilizer. The lawn was designed for it, and so is my time. I mulch because it's good for the lawn and allows worms to live much close to the surface which is good for the lawn. I use some herbicides but zero fertilizer. This means I cut about every 6 days where many have to cut every3 because of fertilizer. I irrigate less often than my neighbors also.
Lastly, I have steep sidehills for my liking but I don't cut full speed on those either because I'm not in a race to get hurt.
Yes, on my less quality flat yard I can cut in either low or high gear but in high gear I don't go at full speed accelerator because it's washboard so I go in high but only mid accelerator.
I'm guessing someone is encouraging you to either get a standard deck that they have in-stock or a zero turn mower because you combine 6 inch height with "how fast". That's fine. But there is no way I can render opinions on your lawn density or quality because I can't see I and I don't know the growing conditions you establish for it.
What I can tell you is I have lots of small knolls and I don't have problems with scalping because my deck has 4 outside wheels plus a front roller and 3 hiiden rear rollers.
By the way, when I bought my mulcher I cost less than the standard 60 inch deck (they didn't have the drive on then).
In 3 years, I've sharpened the blades once at the end of each year and as a result I've never needed more blades (neither 3 or all 6 blades).
Axlehub, the speed question relates to the large flat spaces that we need to mow. It takes about 3 hours to mow all of our lawn.
My concern about the slopes is that in some places we mow near the pond are about 22° and have to be mowed across the slope not up and down.
Will a GC1715 handle mowing a 22° slope? I currently mow it with both my IH 424 with a Ford 74" 917 flail and a Husqvarna lawn tractor with a 54" deck.
I'm interested is knowing the low range speed to use a mowing calculator.
