Best Method to Make Trails
/ Best Method to Make Trails #1
Kyle241
Platinum Member
Eastern Ontario
Kubota MX5100
I'm increasing the trail system I have on my property and last year I got lazy and hired a local guy with a dozer to come in and clear our a trail to the back of my property. Unfortunately the area I wanted him to focus on was a low lying area that I had concerns he would get stuck in, he said he wouldn't but I was proved right. He also cleaned-up a trail I had made in the higher area of my property but now I want to increase my tail system and do not want to hire him, I'd rather save some money and do it myself. I have a B20 and know it's under powered to do the job quickly but it's a little tank and I know can get the job done. My concern is that I do not currently have any attachments other than the loader and BH to assist to make a trail smooth and flat. Is a box blade the best all round attachment to make a trail? I've been considering upgrading my tractor (40-50hp) for a few months and that is why I have not gone out and bought a BB for my B20. I have also considered renting a dozer myself (CAT D4) for a week or so and just going to town on the trails and anything else I need to do.
As for the low lying area, my job this fall is to make a corduroy road as it's too far back to bring in stone/gravel and there's about 1-2ft of peat and removing that would be a huge effort.
Tks.
/ Best Method to Make Trails #2
They dont get stuck in the mud, and you've never had a better nights sleep in your life. :D
/ Best Method to Make Trails #3
I'll be watching this thread as I'm interested as well.
/ Best Method to Make Trails #4
On a serious note, whats the intent of the trails? If you plan to rent a D4 sounds like you are cutting an unimproved road rather than a trail?
Equipment movement to maintain the property?
Ride horses?
ATV's?
Romantic Moonlit Strolls?
The use would determine how I cut the trails if I were doing it for myself.
Ride horses?
ATV's?
The trails will be primarily walking paths through the property and also accessing trees for firewood. Could one day be for horses as well but that is a ways off. The D4 idea is that they tend to make a good smooth trail, can push anything I'll run into (I'm avoiding large trees on my trail) and I want it wide enough that the forest will not encroach too much in the first year. I'll use my bush hog for any cutting of weeds/undergrowth that may come up so I really want to avoid how it is now which is bumpy due to embedded stones and some low pockets.
Tks.
/ Best Method to Make Trails #6
The newer dozers have a pretty quick learning curve as they have the joystick controls. They also typically have 6 way blades that can level out your uneven parts of the trail. And, it's some great seat time.....
Check the blade widths, they're anywhere from 8-10 feet.
that would be my vote!
/ Best Method to Make Trails #7
Is that George Bush up there?? :thumbsup:
/ Best Method to Make Trails #8
Look into a sublease or rental of a small dozer, if you look hard enough deals can be had...check pool companies, concrete companies, construction companies etc. Lots of guys can be had cheap for a few hours on a Saturday morning, then you can clean up and maintain with a box blade. I got 1,800 feet of trail dozed for a couple of sheet pizzas once, the machine was already on site and he just made two passes, one in one out, I cleaned it up with the box scraper and it is like a highway now.
/ Best Method to Make Trails #10
I have cut about 2 miles of trails on our property in the last year with my JD990. I have a bush hog, FEL, backhoe, and a chainsaw. My trails are for walking/ATV riding. I would not have done it with a dozer if I had one. I wanted for the area to remain as natural as possible and not disturb the soil any more than I had to. It is a lot of work, but I find that part rewarding. I avoided any very large trees, cut the saplings with the bushog, cut the midsize stuff with the chainsaw, and dug out the stumps with the backhoe.
Edit to add, I also bought a 3 point hitch chipper and chipped all the brush and put it back down on the trails.
/ Best Method to Make Trails #11
Nice horse team!
I think a dozer would be the best thing.
I have trails that I have pushed out with the FEL and done a little backhoe work on. I think you will beat your tractor to death trying to use it unless your ground is considerably more 'tractor friendly' than mine. I have stumps to deal with and rocks. Some I can dig up and move and some I can't - or it would be a month long project. I never know what is attached to the rocks that stick up or are in the way; could fit in my FEL bucket, or they could be half the size of my tractor.
In any case, make your trail about three-four times wider than you think necessary. The trees will grow in from the sides reaching for the light you have opened up. You can't bush hog a limb coming off a tree 4' in the air. :) All you can do is prune those back. Eventually, the tree crowns will shade the trail enough to limit growth, but the first 10-12 years or so are constant maintenance unless you are making a trail through already mature trees.
Dave.
/ Best Method to Make Trails #12
I've just finished about the first mile or so of horse trails through our woods. I have a L3130 Kubota with FEL, 6' box blade and backhoe. The underbrush was dense. First pass involved using the chainsaw to take down anything the tractor couldn't push over and to rough out the clearing. I bucked this and laid it aside. Second couple of passes was with the box blade, teeth projecting an inch or so below the blade so I could tear up the surface and any smaller plants while trying to leave large tree roots untouched. There were some places across streams and watercourses I needed to install culverts and used the backhoe to excavate and backfill. Lastly, I chipped all the slash to form trail dressing.
I've attached a couple shots, one shows typical density of underbrush before I began, the others a view of part of the completed trail. The chipped material which has yet to be spread can be seen in piles at the edge of the trail.
I should add I took down just about all the maples, young and old, along the trail or on the side of it - they're the widow makers in this neck of the woods.
/ Best Method to Make Trails #13
Well so much depends on the terrain. If it's flat, you can use a bush hog and then a box blade with rippers. That assumes it's level enough that the tractor can operate.
Here, my trails go across some pretty steep slopes. On mild slopes, I've just used a box blade. One steeper sectons, I've done some with a small backhoe (B-21) but it's slow going and a bit worrysome about making a mistake on the slopes.
I've contracted out some for a bulldozer and he did an excellent job for $500/day.
Now I've moved up to a mini excavator (KX-121) and it can handle just about anything. Follow up with the tractor and box blade.
Probably the hiring a contractor with a bulldozer is the most economical. But doing it yourself is more fun.
Ken
/ Best Method to Make Trails #14
Ken
Ken-
That's quite the slope you got there!!
I'm leaning towards renting the dozer for a few reasons:
1) It would be more fun for me to do it. :D
2) I have an area behind the house that has a lot of trees to be removed as we want to open it up more due to all the bugs we experience during the summer.
3) I would be more careful with my property than a contractor would be. A good contractor will be careful to some extent but I have experienced where they think brush and stuff should go and it's not the same place that I thought would be best. Getting a good contractor around here is hard thing to do.
I figure to remove the trees behind the house, a guy will come in with an excavator at $120/hr and he'll make quick work of trees but he'll leave uneven ground so I would have to get a dozer in as well at $60/70hr. My guess is two days work they'll be done and I'll have a bill of $2500 or so. Plus I will have to cut-up the trees and dispose of all the stumps. Now the excavator guy could have time to bury the stumps but I would have to be huffing right beside him cutting the trees for the stumps to be buried.
The ideal world would be for me to own a dozer and do this work plus start on my pond that I have been waiting to do. I could use some of that dirt to fill in my trail in the low area of my property as that is exactly where the pond was going to be placed. The problem with this plan is owning the dozer, not the money to buy necessarily, it's the possible breakdowns. They can get very costly and that is the problem. I could see me buying a used dozer for $20-30k and wind up with a $5-10k+ repair job. I would sell the dozer when finished with the jobs though as I have no use for it after that.
So renting a dozer is possibly a good idea but I can't get all the above done in a week! The pond idea would have to simmer on the stove for a while longer.
/ Best Method to Make Trails #16
A good excavator operator can do a fair job of leveling the ground. The weight of the machine will pack it down. You can do final grading with your tractor and FEL or boxblade.
Ken
/ Best Method to Make Trails #17
Ken-
Yes it is :) Originally it was a deer trail. I widened it enough with a mattock in the bad spots to use it as a horse trail but maintenance was a pain. Now I can get through it with the 4 wheeler.
Ken
/ Best Method to Make Trails #18
If you just want the trails for walking paths, horses, etc I think a dozer is WAY overkill. Also, the new dozer while easier to run than older ones, will still make just as big of a mess in the hands of an inexperienced operator. A six way blade seems like an easy concept, but really getting it to do what you want takes many hours experience.
I've built quite a few trails on our place with my B3200 equipped with loader, tooth bar and box blade. I just work slowly and meticulously and go around trees that are too big to dig out. I've even cut in some pretty good side hill trails. Attached are a few pics of some of my more recent trails, first one is an ATV trail, others are a section of trail that connects two other logging trails.
I can't disagree with you, this is one of my concerns as well. A dozer makes a trail easily but it's a big heavy machine that can easily damage and roots of large trees that I want to keep and happen to be close to the trail. I've ran a dozer before so I'm not too concerned about my skill but again it's a big machine for just a trail.
I like what you've done for your trails. Very nice indeed. From what I can see of your trails, is it mostly sandy loam? Here I have what we call stoney loam! A lot of good sized stones that may appear two feet round until you try to dig them up and they are a boulder. I have been thinking over my plans and wondering whether I can do the same as you have. The difference would be that I would upgrade my tractor which was in the plans anyways to a MX5100 with BH96, Bushhog BB and tooth bar. This tractor would have a lot more power than my B20 and instead of paying $1500-2000 for someone else to do the work or renting a dozer, it can go towards the tractor. My only concern is whether I can do the work needed to remove all the trees and level the ground directly behind my house as that area needs some attention.
I'll have to search on this forum for removing trees with a tractor. I have can do it the old way, cut the tree and then remove the stump but even with the new BH 96, this would take some time with the amount of trees that need to go.
/ Best Method to Make Trails #20
Kyle -
Thinking more about you're situation and what you're wanting to do, I think buying (or renting) an excavator would suit you better. For removing trees - an excavator is the easiest. Get a high spot on the tree, and start pushing......tree down. If it's a big tree, you can dig out around the root system prior to pushing it over. More importantly, stump out. Fill in the hole. Then decide to burn/bury stumps.
Rocks - excavator.
Pond - excavator. And you can load dirt on a truck/trailer if you've moving the dirt.
Trails - as Ken has stated/shown, perhaps a bit slower than a dozer, but much more capable than tractor alone.
And - you never said how many feet/yards/miles of trails you want to do? I have nothing against a tractor, but it will take a lot longer to do than excavator/dozer.
As someone else already mentioned, making the trails a bit wider is a good thing....very easy to grow right back in. Nothing like getting whacked in the face with a bramble/branch/thorn bush that wasn't there last year!
I took a chance and bought my own dozer and excavator for trails/trees/ponds/homesite, etc. I am taking a chance on future repairs, but know a equipment mechanic that can do nearly any repair onsite and much cheaper. Not to mention some great seattime. :cool: I haven't regretted it one bit thus far.....:D
Many folks buy/use/sell equipment for the very same purposes.
Perhaps a mini-ex like Kens would suit your needs....and many of them are equipped with a front blade, which would greatly help your needs.
With all you're needs, I would spend the money on a mini-ex instead of the larger tractor.....then you'll have both to give you the greatest flexibility.
good luck!
