Best fence options
/ Best fence options #21
Great information so far! I don't want to sidetrack the thread too much, but... I'm putting in a fence right now. I'm using the 3.5" PT posts and dug the holes with a 9" auger bit. I was delegent in tamping the posts in with the existing soil, but still have a bit of wiggle.
What are some of the tricks to eliminate post wiggle? or maybe some wiggle is acceptable and the WWF will help strengthen them as a unit?
Thanks for any insight. tony
/ Best fence options #22
I don't board horses.. and you can get t-post caps for them to make them less likely to get punctured.
I've seen stabbed horses from broken shards of fence boards.
I personally own a horse that managed to get a shard of fence board stuck into it's head, under the eye..
Board for horses is common.. but in many parts of the country, hi tensile wire and barb wire is just as common...
I've never had a horse walk down a fence, barbed, electrified or not... but then.. i don't keep warmbloods or draft horses either... just mules, quarters and mini's.
by the way.. 10ac of electric fence is EZ to keep working..
Soundguy
zzvyb6 said:
The man said 'possibly horses'. I'd never use T posts for horses because they learn how to walk them down and if they jump up to chase a fly, they will get punctured. T posts will need to be electrified for horses. That 10 acres of WORKING electric fence.
Barbed wire never stopped a horse until its too late. If you ever board other's horses, they will probably reneg when they see the wire. My treated landscape timbers have lasted 15+ years, even the ones in the swamp. New pallets I just purchased to run some lanes in my fields went for $1.50 a piece from Lowes last fall. That's a lot cheaper than 4x4's or 6' cedar, You set the landscape timber so the strong side is out, not sideways. (Yes, I've seen the geneous side of civilization).
/ Best fence options #23
2x4 no climb woven wire is probably used for horses around here more than 3 or 4 board fencing.
Go out west and you see barb wire used for everything.
It's my 'last choice' for a horse.. but if your animals aren't particularly stupid.. you will have few problems. My mule has been in barb wire his entire life.. he has not a single scratch on his body or face.
My other horses are similar.. one I got from the water district.. they kept that animal in barb it's entire life. had a scratch or two on the muzzle.. nothing worse than I've got on my arms from just being alive on this planet..
There are plenty of ways to mitigate a fenceline and make it safer for an animal.
You can go to stranded hi tensile wire.. etc.
I've personally seen more animals maimed by electric wire embeded poly tape than i have any other fence material.. as for cattle.. well.. stronger is better.. and a deterrent is good.. but a charging bull will go thru anything not made of concrete.. if it wants to. And buffalo are 10x worse.
soundguy
VAChesterfield said:
A fence for both dogs and horses really means woven wire. While the woven wire will work well for the dogs, woven wire is less than ideal for horses. Barbed wire is absolutely a no go unless you like Vet bills.
When using woven wire for horses, PLEASE use only woven wire especially designed for horses. This kind of fencing has very small openings to preclude the horse from putting its hoof through the fence and injuring itself.
Examples are posted on this site Horse Fencing Systems for the Equine Industry - RAMM
I used Ramm's Flex-Fence and love it. Easy to erect and care for, and easy on the horses too.
Like several others who have posted, I like to use round posts for my fencing ... horses are powerful, inquisitive creatures and they will often test a fence. T-Posts are OK, but will need at least one strand of electrified wire to keep the horses away.
If you use wooden posts, I recommend using one 60lb bag of concrete for each line post and two bags for each corner post. Unless your ground is very dry, there is no need to mix the concrete. Just dump the bag into the bottom of the hole, maybe add a bit of water, then fill in with dirt.
/ Best fence options #24
I agree with soundguy that barbed wire fence and t posts work fine for horses. That's what most people around my area use. Of course if you're running high dollar horses, then you can afford to run a high dollar fence. I've never had any problems with my horses and barbed wire fence, but I did have a neighbor whose horse got cut on the chest from a low t post.
/ Best fence options #26
Hello All,
We have 3 acres fenced off for our show horses, we use Poly tape with T-posts covered with a 2 x 2" PVC sleeve with caps, The Poly Tape is mounted to the 2 x 2 PVC with clips. The corners are 4 x 4 x 8 with a PVC sleeve. The entire fence is electrified and is the most horse safe fence we've found. Easy maintenance and can be repaired quickly.
Malvern
/ Best fence options #27
Anyone who suggests barbwire to contain horses must have stock in their local vet...:rolleyes:
A neighbor, who knew better than us...:rolleyes:...when advised about their fencing, has had one of their expensive 3 day eventer, that has been in treatment for getting cutup in their barbwire fence, out of service of serveral months...not counting the emergency call, initial treatments and then the weekly vet visits...I would hate to think what it has cost her...
Barbwire...not for expensive competition horses...:D
T-posts are no problem...as long as you cap them as has been mentioned...
Electrical fencing in snow country requires that you run a ground wire along with the hot wire, because our snow pack will actually insulate them from be jolted if all you run is hot wires on you fence...Demonstrated by a neighbor whose horses ended up at my barn...:D
/ Best fence options #28
I believe it was already mentioned that if you owned a million dollar horse.. something other than barbwire should be used.. also.. if you have warmbloods, drafts, or stalions, you need better fence.
If you have some mild pleasure horses that just pull grass all day, and mosey around tot he water trough now and then and come up to eat a handfull of carrots .. etc.. you may be able to get away with it.. Lots of variables... much of it the animals disposition.
Amount of land you are maintaining makes a difference too. if you have hundreds and thousands of AC. then 4 board with no climb wire might be something that donald trump or bill gates maybee could buy to keep a few hay burners in... but most are going for stranded wire. Like I said.. my horses in b-wire have never had a vet issue... I have had a horse in board fence get poked by a broken board though... not sugesting anybody do either or.. just relating my experiences. Anyone that don't like my fence is welcome to stop by and upgrade it on their nickle -anytime-.
soundguy
Is it too late to rein this thread in a little and focus on canines? I may preserve my options to contain horses, but my primary goal is the dog world. Are there any issues that I should be aware of regarding pooch running about? Fence height, buried portion, posts, weave, etc.?
jmf
/ Best fence options #30
jmf
What kind of dog are you trying to keep in? Makes a big difference, we had a Queensland Healer a few years back, and he would clear a 5' fence no problem. I had to go to 6' and that pretty much stopped him. Small dogs and you will need fence with smaller holes etc. A lot depends on what type of dogs you have.
/ Best fence options #31
Fence for a dog depends on the dog. I owned a black lab that would climb anything you put in front of it. I worked several days to put up an 8' chain link fence and thought - finally my dog will be safe and not run off. I shut the dog in the yard with the 8' tall fence and walked out into the field and she was at my side in a matter of minutes. :eek: My wife laughed long and hard about that. She simply climbed the fence and jumped. With her it had to have a lid on it.
On the horse issue, DON'T USE BARBED WIRE! ALL horses will spook from time to time and you just don't need the after effects of horse-barbed wire encounter. JMHO
/ Best fence options #32
Yep.. 2x4 with the 'V' no climb is about the only thing that will keep climbing dogs and goats in..
soundguy
I will be leasing the land to dog owner's so there will be a variety.
jmf
/ Best fence options #34
I've always jammed rocks or wood down the hole to eliminate any play in the post. Anything solid will do. Scrap pieces of wood are good for this.
/ Best fence options #35
You might want to check out Premier 1 fencing. They have a variety of fences illustrated.
If you don't know the dogs, then you will probably want to count on high jumpers, climbers and diggers. That means mesh, and low, and high electric lines.
I recommend grounding the electric fence to ground rods and to the non-electrified wire. If you use wood posts exclusively, add metal ground posts around the perimeter to help get a good zap. I would also recommend buying a good, modern, variable impeadance charger; it will make a world of difference.
I believe in fencing once, and then not revisiting it. The first fence that I built is still going strong 35 years later, but different soils, weather, and fence materials will have different lifetimes. Of course, cash on hand makes one settle for interim solutions sometimes.
Another poster mentioned wiggly posts. These shouldn't happen. Either tamp harder, more often, or set your post deeper. If you are setting posts in something really soft like peat, you may have to drive it a long way down. If the posts wiggle, the fence won't last.
Fence types are a bit like religion; it is hard to convince someone that to have a rational discussion about it. (Rather like pickups and tractors, too...)
Having said that, I don't think that any particular fence is intrinsically safe or unsafe. How it is installed, maintained, and used makes all the difference. You may see barbed wire cattle fence where there isn't much pressure on it, out in the pasture, but in a feedlot, you'll see alot more railroad ties and guard rails. One of our horses had a leg tied up to be shod at his trainer's(at a cattle feedlot), and deftly hopped up, hit a cattle fence made of railroad ties and a five foot high wall of solid 3x12" and went through it sideways. A dumb action rendered a great fence a problem. YMMV. He still doesn't like to have his hind feet handled for some reason... :)
All the best,
Peter
jmf
/ Best fence options #36
jmf
What exactly are you planning to do with these dogs?
How many?
What types?
Under supervision?
Have you determined if your land has plants dangerous to dogs?
What is you plan for manure control?
We're not talking another Michael Vick operation?...are we?
How are you planning on protecting yourself from a liabilities arising from said lease?
I'm leasing my property to dog owners who want to exercise their animals. The lessee will be responsibile for their dog (insurance, supervision, etc.). As to manure I will till it into the soil. Narcissist and sociopaths need not apply.
jmf
/ Best fence options #38
Think of hogs, not dogs, and they probably won't get out. Use woven wired and bury about 6 inches of it along the line with the rest above. Unless you have a jumper or climber, that is. You could take care of them by having some of the fence angled back into your contained area, kind of like the fencing that keeps urban types from throwing rocks off bridges onto passing cars.
Around here, the guys who build fences use a hydraulic post(pile?) driver to simply hammer treated wooden posts into the ground. I had one run a 9 wire high tensile fence with alternating hot and grounded wires to contain sheep and keep out dogs and coyotes. He had an Allis D-17 with a big post driver mounted on the front. He drove that not too small tractor/driver backwards down a wooded hillside on rocky ground, driving 8 foot posts 3 feet into the ground about every 20 feet. I asked him what happened if it hit a solid rock and he said it either shattered the rock (mostly sandstone, but occasionally pretty thick) or mushroomed the post bottom. Either way, the posts don't move. A maple tree fell on one and the post snapped about 6 inches below the surface, but the "stump" was very solid in the hole. He said he could drill them, but it takes a lot longer and doesn't work as well.
What do the use to make the 6" cut below the fence?
jmf
/ Best fence options #40
You could use your tractor's FEL...push it into the dirt and the roll the bucket a little...
or you could use a walk behind trencher to create a slot on the ground to drop the fence material into...but if the dogs will be supervised...:rolleyes:...it may not be necessary.
