Bent Rotary Cutter Deck - Can it be Fixed?
   / Bent Rotary Cutter Deck - Can it be Fixed? #31
I'm not familiar with that floating toplink, but it looks like it would work better with the QH hook removed. As it is now, the rear of the deck can't go any higher. the pin is already bottomed out in the hook. The rear could drop very slightly (only enough to get the link pieces straight).
Good call. Although I went through the setup procedure, I didn't get it completely dialed in. Here's the setup instruction set (kinda weak):
And here are my results...Just as shown and much more flex at the top link:
And this is the off-ground condition:
   / Bent Rotary Cutter Deck - Can it be Fixed? #33
Your second picture with the hook lowered looks better.
Hydraulic Breaker Excavator Attachment (A55973)
Hydraulic Breaker...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2022 JOHN DEERE 330G SKID STEER (A52705)
2022 JOHN DEERE...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
CASE 584E ALL TERRAIN FORKLIFT (A52708)
CASE 584E ALL...
TROY BILT GAS POWERED POWER WASHER (A58374)
TROY BILT GAS...
