Bent Rotary Cutter Deck - Can it be Fixed?
   / Bent Rotary Cutter Deck - Can it be Fixed? #31
I'm not familiar with that floating toplink, but it looks like it would work better with the QH hook removed. As it is now, the rear of the deck can't go any higher. the pin is already bottomed out in the hook. The rear could drop very slightly (only enough to get the link pieces straight).
Good call. Although I went through the setup procedure, I didn't get it completely dialed in. Here's the setup instruction set (kinda weak):
And here are my results...Just as shown and much more flex at the top link:
And this is the off-ground condition:
   / Bent Rotary Cutter Deck - Can it be Fixed? #33
Your second picture with the hook lowered looks better.
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
MANTLE & CHIMNEY FOR FIREPLACE (A58374)
MANTLE & CHIMNEY...
AG-FAB PULL TYPE SWEEPER (A58374)
AG-FAB PULL TYPE...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
