Bent Loader Bucket
/ Bent Loader Bucket #1
gilbertmsg
Disputanta, VA
2007 Kioti CK20
I added a thumb to my bucket. Went for a test and bent the top of my bucket about 2-3 inches up. Tried attaching a chain and using bucket to pull back down with no luck. Just looking for some ideas before taking to welding shop and having entire top cut and replaced.
Eddie
/ Bent Loader Bucket #2
May need heat and a hydraulic press to put back in place. The upper edge of a bucket is not very strong as you discovered. It will need to be reinforces quite a bit to support a thumb. I reinforce all my buckets and I don't use a thumb. Eventually they all bend anyways.
andy
/ Bent Loader Bucket #3
Heavy duty "C" clamps and sturdy angle should straighten that out.
Tighten the clamps to pull the bend inwards with an occasional wack with a sledge hammer to coax the bend back.
You could also cut the flange before bending back and once straight re-enforce with a welded in place angle/doubler.
2012 Sun Coast Trailers 12ft S/A Enclosed Trailer (A61569)
2012 Sun Coast...
UNUSED KJ 14' EXPANDABLE SITE FENCE (A62131)
UNUSED KJ 14'...
New/Unused 20x30 All Steel Carport (A61166)
New/Unused 20x30...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
207271 (A52708)
207271 (A52708)
iDrive TDS-2010H...
