Bent check chain
/ Bent check chain #1
johnpc
Northern NH
Kubota B2620
After a day of pulling logs and brush and raking over a few washouts on the road I noticed I had bent the upper half of my right check chain. I had a big clevis attached to my drawbar and think it must have swung wide and got over the check chain before I brought up the 3 pt arms but this is only a guess. Is it a problem? How, if possible, can I bend it back? Should I get it replaced?
/ Bent check chain #3
I'd try to bend it back...nothing to lose, it isn't gonna be right like it is, if you can fix it- great, if not well you need a new one anyhow...
/ Bent check chain #4
Mine on my 4150 have always had issues, but I've never found a heavy duty replacement. I'd bend it back for now, chances are it will never bother. Keep it lubed with anti-seize as well, they tend to get sticky after a while.
/ Bent check chain #5
it may have cracks in the bottom of the threads and bending it again may only worsen any cracks
so if its a safty issue replace it
it looks like something easy to make or have made
/ Bent check chain #6
"have made"
Maybe!
Providing you are not needing a metric left hand thread.
I faced the same problem and purchased an after market pair at less than 1/2 price of machine shop charges (not all shops have metric left and right taps and dies) and about 20% of factory new part plus I ended up with a whole new pair of 'after market' replacements with the OEM parts as spares.
My 'after markets' (in my opinion) were actually better than the OEM as to design and 'beefyness' .
They have now served me 6 (hard) months with no indications of weekness.
/ Bent check chain #7
if its a self contained unit then metric wouldnt be necessary, in that case a large turnbuckle could be adaped
i have a welder and cutting outfit so my first thought is to make it myself
if they are cheaply avaliable then thats the way to go
i buy stuff when its cheaper and less time consuming, im not wedded to the i have to make it myself, too much to do
mcmaster.com has left hand threaded rod and nuts
a nut could be put at both ends on the shackle and the turn buckle that way if you bend it again just replace the threaded rod
/ Bent check chain #8
It sure is a perfect time to switch to the telescoping stabilizer links, ~$60 when I changed mine and won't go back to a turnbuckle and wrench. Lots of threads here and it's simple to do.
/ Bent check chain #9
SO Jerrys post with this item is either to expensive or isn't rugged enough?
Surplus Center Item Detail
It says it is designed for it..
ADJUSTABLE KUBOTA SWAY LINK TURNBUCKLE
/ Bent check chain #10
For now, I too would just bend it back and use it till it breaks completely.
You can always order the replacement for when that happens again.
/ Bent check chain #11
May or may not be a deal, depends on if it is the correct size, it obviously isn't the same as the one the OP bent.....
That said $4 for just about ANY turnbuckle that large is a great price if you've priced generic ones lately:D I've got a few on the way just because...I might need some one day, for something....don't know what yet:eek:
/ Bent check chain #12
Thats is an awesome deal, I've got an order for a couple of these too. I was looking at Crosby turnbuckles recently for this same use and one that size was almost $60 each.
/ Bent check chain #13
I would agree with those that say bend it back and see how it goes. I've bent a few of those and straightened them out with out a hitch. Take a torch heat it up and slowly straighten it in a vise. It will be close to good as new, From experience I have yet to actually replace one on a large machine, unless of course I snapped it in half while trying to straighten it. :)
Good luck!
Jim
/ Bent check chain
Check chain straightened! I fix computers and the last stop today was at a machine shop. After replacing computer part I asked owner if he could straighten a threaded rod for me. He said it should not be a problem and we went over to a table vice/material holder and he took a look at the check chain and asked if it was from a Kubota. He then told me about his B3030 and I told him about my B2620.............He straightened the rod and ran a die over it to clean up the threads. Thanks George Abbott of Abbott Machine Shop in Conway, NH and thanks to everyone for their suggestions.
17in. Bucket w/ Teeth Excavator Attachment (A68183)
17in. Bucket w/...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
CAT 963C Multi-Shank Ripper (A68134)
CAT 963C...
2012 Gillig G27B102N4 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
2016 Nissan Altima Sedan (A66738)
2016 Nissan Altima...
2005 INTERNATIONAL (INOPERABLE) DURASTAR 4300 (A67714)
2005 INTERNATIONAL...
