Belt for 48" deck
   / Belt for 48" deck #1
ldabe
SE, Michigan
PT-422 2002 Robin eng.
I need a new belt for my PT 422 48" mower deck (T3035).
I looked at the Power-Trac site but did not see where to order.
But also, if I could I was wondering if there is a place close to me that I could get the same belt size?
Does anyone know or has anyone done this for the mower belt?
   / Belt for 48" deck #2
I got mine at Tractor Supply Co. just be sure you have the correct width..take the belt with you and match it up.
   / Belt for 48" deck
Thanks Farmall140,
Just another good reason to go through TSC ;~)
But, do you think the belt is stretched out by use, and should I take that into consideration in selecting a slightly smaller belt size?
   / Belt for 48" deck #4
It's been awhile but I think the size I got from TSC was the closest I could find without going over the size of the used belt. The deck does have an adjustment for tension. My original belt became "chewed up" partly due to debris under the deck covers...I have since removed the covers hoping this will prolong the life of the belt. Now the leaf blower removes all debris quickly and this also allows you to keep an eye on the tension over time.
   / Belt for 48" deck #5
I purchased a backup belt at NAPA. The number is A105. My original belt is still holding so I have not installed the spare.
Dale
   / Belt for 48" deck
Thanks guys.
I will check both places out, since they are fairly close to drive to.
   / Belt for 48" deck #7
Look for a 1/2" X 105 " belt. Here is what my belt looked like after 2 1/2 mowing seasons.
   / Belt for 48" deck #8
Would it help to extend belt life if you engage the PTO with the engine going slow (maybe idle or just above). This reduces that startup shock which can take those notches out of the belt. I do this for the bush hog if I remember, to reduce the clunk. No belt there of course.
   / Belt for 48" deck #9
Bob,
that's a good point. I always forget that the PTO engagement on the 422 and 425 are different than the 180. The 180 has a manual lever on the side of the tunnel so any PTO driven attachment can be engaged slowly almost like a soft start electric motor. It works very well without having to throttle the engine way down first.
   / Belt for 48" deck #10
Rivco said:
Bob,
I wonder what the mechanism for the 180 PTO clutch is. Does it have wear during engagement. Perhaps it's like an automotive clutch. Is so you might protect it by slowing the engine down during engagement. Remembering would be the hard thing.
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2021 JOHN DEERE 1725 CCS LOT IDENTIFIER 178 (A53084)
2021 JOHN DEERE...
2020 BOBCAT T76 R-SERIES SKID STEER (A51246)
2020 BOBCAT T76...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
