Belarus 250AS
/ Belarus 250AS #1
packrat1944
Belarus 250AS
I have a Belarus 250AS with two 6volt batteries wired in series to get 12volts.
Since one of the batteries is bad would changing to one 12volt battery be a problem?
/ Belarus 250AS #3
That should be ok.
/ Belarus 250AS #5
Welcome packrat1944! Years ago i had 2 Belarus 400's They originally had 6 volt batteries. The Belarus dealer i bought the tractors from changed it to 2 12volt batteries. No problems and had a lot more cranking amps. John
/ Belarus 250AS #6
I have a 250as and it has one twelve volt battery. The advantage of having 2 6 volt batteries is that the amps will add up, giving you 12,volts with i.e. (if you have 500 cold cranking amps, on each of these 6 volts batteries, you end up with 1000 cold cranking amps) good to know when you are selecting your 12 volt battery/.
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
Landhonor Mini Skid Loader (A66285)
Landhonor Mini...
