Belarus 250AS
/ Belarus 250AS #1
packrat1944
Belarus 250AS
I have a Belarus 250AS with two 6volt batteries wired in series to get 12volts.
Since one of the batteries is bad would changing to one 12volt battery be a problem?
/ Belarus 250AS #3
That should be ok.
/ Belarus 250AS #5
Welcome packrat1944! Years ago i had 2 Belarus 400's They originally had 6 volt batteries. The Belarus dealer i bought the tractors from changed it to 2 12volt batteries. No problems and had a lot more cranking amps. John
/ Belarus 250AS #6
I have a 250as and it has one twelve volt battery. The advantage of having 2 6 volt batteries is that the amps will add up, giving you 12,volts with i.e. (if you have 500 cold cranking amps, on each of these 6 volts batteries, you end up with 1000 cold cranking amps) good to know when you are selecting your 12 volt battery/.
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
3146 (A63117)
3146 (A63117)
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
