BELARUS 250AS
/ BELARUS 250AS #1
Gizmo36
Platinum Member
East of Duewest S.C.
A man a few miles from here has two Belarus 250AS . He got them new from a dealer in 1987 .He has not been able to sale them. I told him about 6 years ago that I would not have them. one has about 250 hours on it . One has about 400 on it. He wants a plow that I have it is about 800$ . The two run good right now. But would they bring 800$ for junk when they stop running.I am thinking about trading for them.. And let the deer hunters use them that hunt on my land.
/ BELARUS 250AS #2
Problem is is that they already ARE wore out!:D
/ BELARUS 250AS #4
Depends if you have a use for the tractors. They are worthless on the market but when they run they run and do what tractors generally do. There are thousands of these things on the road and farm in Eastern Europe and Russia. I'm sure they require tinkering but they are proven if lower grade tractors.
/ BELARUS 250AS #5
Well I'm not a Belarus fan for sure. I used to own one that was about 75 or 80 hp(an 825 I think) that I bought new. It never failed to start though no matter how cold. I think that was the number one reason I kept it so long. If you wanting it for someone to putter around on and don't really care if the tear it up, those would be cheap enough to fit the bill. I have seen this model bring pretty decent prices on ebay if they look ok. Parts are available online for them the last I heard.
/ BELARUS 250AS #6
Personally, I would do it in a heart beat. They bring $1500-$2000+ regularly on Ebay. Doing a search on completed auctions in January '08 showed that all recent 250AS were bid up to +$2000. Only one was bid up to less ($1625, it sold with a bad clutch). For referrence, the tractors the search brought up were located in Tenn, NC, OH, Arkansas and MO. Sounds like a no-brainer to me. I'd have that plow in his yard and 2 tractors in mine today if it were up to me!
/ BELARUS 250AS #7
I don't see why Belarus has such a bad reputation on this board. I have known several people who had or still have them and never have problems with them. These are 60+hp farm tractors, not smaller ones though. My uncle owned a 500 series for about 15 years and finally traded it in on a Massey because he wanted something with more features. They are a basic and cheap tractor, but not worthless.
I would jump at that trade for the two 250AS' for a plow. For scrap metal alone they are worth about $250 a piece, so your not taking that big of a financial chance. JMHO
/ BELARUS 250AS #8
Belarus tractors are a good news bad news story. The good news is they are low tech and can be maintained with rather primitive facilities. The bad news is that they often require lots of the low tech maint.
If the two tractors are the same, at least you should be able to keep one of them running by cannibalizing one to fix the other.
I had a chance to buy one but passed. I thought it was way too crude and I don't do well with the Russian's Cyrillic alphabet. Even the owner didn't know how to shift all the gears and everything was labeled in Russian.
$800 for two would be a fair experiment, especially if you don't expect to have to use them for much.
Pat
/ BELARUS 250AS #10
A farmer neighbor has a Belarus, 70hp w/cab that he bought new about '86 or '87 and has used it since then, uses it to feed his dairy cows twice a day every day and the only thing he's complained about is fanbelt use.
/ BELARUS 250AS #11
I have a 250as that I bought new in 1992. In 16 years I have kept it serviced and had one problem with hydraulics when it had 2 hours on it and was fixed under warranty.It is very simple and crude but everything is simple to fix also they are air cooled engines so there is no coolant problems to worry with and the only filters to change are fuel filters which you can get easily, even the oil filter is slinger type.(you just take apart wash and reinstall) the hydraulics use 30wt motor oil. it is approx 32 horsepower but with super long stroke engine the torque curve is great. would I recomend new one? NO! but if plow is of no use and you can use tractors I dont see where you could go wrong they are tough and heavy. I kept mine even after I was able to afford newer and better tractors, since they are not worth alot there was no use trading them . I still use mine to mow with it has about 1000 hours on the meter and if it quits tommorow I feel it paid for itself.
/ BELARUS 250AS #12
I talked to a MF and Montana dealer last week who is in a town where one of the largest dealers for Belarus's in Eastern OK and Western AR was located. He has 2 of that dealerships former mechanics and he loves Belarus. He says 80% of his shop business is working on them because he is one of the few places that will mess with them. Parts are actually cheaper now than in the early 90's. My water pump started leaking when the tractor was about 2 years old. A new waterpump was $1000, when they could get them. Now they are about $200. My waterpump was still leaking when I sold it, along with that crazy hydraulic system(odd size O-rings), the oil cooler,(which was in front of the radiator and caused to to oil up and overheat) and the fuel system at times. The larger ones were well known for the front steering cylinder falling off.(mine did:eek: ) Air conditioning on the cabs(all aftermarket)was very poor.:mad:
Like I said though it never failed to start. The 4 wheel drive worked pretty good and it made a good tractor to feed out of in the winter(the heater would run you out). If you bought one new, you really got the screws put to you when you sold it.
I never had one of the air cooled one but looked at them some. As cheap as these are I would probably jump on them, if I didn't have to run it.;)
The dealer I mentioned above actually was approached by Belarus to become a dealer for them because he ordered so many parts. Wholesale price to him for a new 75hp cab tractor was $26,000 at the port, no air, no FEL. He declined the offer.:D
Just my view and experiences with Belarus.
/ BELARUS 250AS
We are having a big sale in Feb.,., 5 of us farmer's are selling a lot of stuff.so the plow would be gone any way. I think I will get them , I don't need any more tractors but the boys up at the farm can use them and that way they won't be coming and getting my tractors that I have to have.
UNUSED KUBOTA BRUSH GUARD (A62130)
UNUSED KUBOTA...
2019 FREIGHTLINER CASCADIA 125  EVOLUTION SLEEPER TRUCK TRACTOR (A59909)
2019 FREIGHTLINER...
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
New/Unused Two Wheeled Electric Bike (A61166)
New/Unused Two...
2016 EH Wachs Trav L Vac Hydro Vacuum Excavator Trailer (A61567)
2016 EH Wachs Trav...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
