Belarus 250 Diesel
/ Belarus 250 Diesel #1
rhesamc
Bridgeport NY
1950 Allis Chalmers
I have a 250 Belarus diesel that runs fine for 10 or 15 minutes than slows right down chugs along with black smoke coming from pipe and then quits. Any thoughts on this problem?
Best place to start is look for fuel restriction, either filter or screen at the tank or junk in the tank blocking outlet.
I changed all filters last year, but I will go back and investigate somw more. Thank you
/ Belarus 250 Diesel #4
Sounds like fuel restriction.. LOOK for floaters in the tank..
You can remove the return line & blow back into the tank.. Do the same for the INLET line..
